Thread: Startup
    Milton Keynes
    Default Startup
    having a bit of a problem... my vectra is stalling on initial start-up, it starts fine, but cuts out, then starts and runs fine everytime?? Any ideas what it could be? Don't want it to be something serious?
    Cheers!
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    mine does the same thing.
    Starts very good and after 5 seconds starting rattle a couple times...
    Don`t know what is it...?!?!?!!?
    Milton Keynes
    I though maybe it is just a sensor problem, but not really sure!?
    Bristol
    Vehicle : CDTI 150
    May be something to check
    Field Remedy: 1995
    Subject: Engine Z22YH - Rattling noise from engine at idle
    Models: Engines: Option:
    Zafira-B 2005...,Vectra-C 2002...,Signum 2003... Z22YH,Z22YH,Z22YH
    Complaint: Rattling noise from engine at idle.
    Cause: Crankcase pressure control valve remains open resulting in mentioned concern.
    Production:
    Remedy:
    In case of customer complaint proceed as follows:
    Open the oil filler cap (hard to open because of the vacuum); if the noise disappears the crankcase ventilation valve is the cause of the rattling noise.
    Remedy: Install a new crankcase ventilation valve (partnumber: 24414343 / cataloguenumber: 56 07 496).
    FunctionalGroup: J - Engine
    Complaint Group: 14 - Noises or Vibrations
    Trouble Code: None
    Sussex
    Does this apply to the 1.8LX as well, as got the same symptoms.
    Nov 2010
    Vectra land
    sounds like engine coolant temp sensor to me
  1. startup issues and some more
    By james walker in forum Engine & Drivetrain
    Last Post: 14th September 2011, 08:53
  2. smoke from cat on startup
    Last Post: 29th August 2011, 20:17
  3. Smokey startup!
    By twaiter in forum Engine & Drivetrain
    Last Post: 29th May 2010, 20:25
  4. Idle on startup
    By Redviper in forum Engine & Drivetrain
    Last Post: 12th January 2010, 10:20
  5. EML On at startup
    By Thebug in forum Engine & Drivetrain
    Last Post: 6th November 2009, 17:34
