Thread: Auto Lights: Anyone tried this?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Auto Lights: Anyone tried this?
    Has anyone tried the Valeo Lights On/OFF . For less than £40 it looks pretty good.
    It consists of a light sensor and some cables that you somehow connect to the lighting circuit. Its got a little button on the sensor to turn the quto function on/off.
    For a few quid more I reckon someone good with soldering could make this look factory.
    The light sensor could be put up by the rear-view mirror, pass the wire through the headlining down the A-Pillar and hook it up with a VX Auto Light switch.
    Any one want to have a go??
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't see why it can't be done. As the switch is not controlling light function directly, it may take a little while to figure out how to connect this up properly.
    What's wrong with just using the light switch to operate lights???
    A light switch circuit diagram might be useful.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Aug 2010
    Antrim
    Quote Originally Posted by Ste View Post
    Auto lights are great. My Mondeo had them as factory fit. There have been a few times when i have driven off in the Vectra without the lights on, because I had got out of the way of having to use the light switch. Not helped by the odd Vectra feature of having the dash illuminated when the lights are not on. Never had a car like that before. Having a dark dash tends to remind you to turn the side/head lights on.
    Jun 2006
    North West
    Quote Originally Posted by WilliamLX View Post
    I agree, the only good thing about the wifes Megane is the auto lights and wipers. Though it won't be long before they will break.
    Plus, it might be a nice little mod to do If only I new how to solder.
    Jul 2009
    The Rift, Cardiff
    I was looking at the same system on the Maplins site almost a year ago, http://www.maplin.co.uk/module.aspx?moduleno=257320
    I asked them if it'll work with canbus cars like the vec c, they said no. I guess because of the rear lights being controlled by the rec at part power (full while braking).
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    They will work with CAN systems, you just have to mimick the function of the switch itself. ie put the yellow and the grey / green wires to either ground or 12V (can't tell from the diagram I posted above whether the wire to pin 35 on body controller is live or ground) and the body controller will just think the switch is being operated.
    I will check tomorrow when I can access TIS.
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    When set to the auto position the lights remain on all of the time. I've only had the car a few days and wonder if there is something that I have done to cause this. Any help appreciated.
  1. Auto lights on / off
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 09:18
  2. Auto Lights
    By Perry in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2008, 22:34
  3. auto lights
    By skyrocketpilot2 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 22:18
  4. auto lights
    By vecdti in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 00:30
  5. Auto lights not very auto
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2008, 22:29
