Thread: fault light ??????????
    Aberdeen Scotland
    confused fault light ??????????
    Hi there just made the journey to work and as i parked up and turned the ignition off a light came up with an oil can and a spanner through it! What does this mean? Is it short of oil? Thanks.
    Aug 2010
    whitley bay
    service light bud just due for one, if youve had it serviced and the garage hasnt reset the light (like me) theres info on here to reset it yourself etc
    hth
    Phil
    Blantyre
    Try this
    How to reset,
    - With the ignition switched off, press and hold in the odometer button;
    - Whilst holding in the odometer button, press and hold the brake pedal;
    - Now, continuing to hold the button and the pedal, switch on the ignition;
    - Hold down the button and pedal until the "INSP" light stops flashing and turns to 3 dashes "---"; and
    - Switch off the ignition.
    Sep 2010
    wakefield
    just done this on my car and it worked fine!
  1. ABS fault light
    Last Post: 5th October 2012, 19:04
  2. 2.0 tdi fault light
    By vauxpower in forum Engine & Drivetrain
    Last Post: 22nd January 2011, 17:54
  3. fault light
    By homerj in forum Engine & Drivetrain
    Last Post: 19th September 2010, 15:56
  4. fault light
    By trev16185 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 19:56
  5. TC AND ABS LIGHT Serious Fault
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2008, 19:49
