Results 1 to 2 of 2
Thread: Advice please
    Jan 2010
    LEICESTER
    Default Advice please
    Is the oil pressure switch easy to replace in the Z22SE.
    Got a fault code saying malfunction and thought I'd just change it along with an oil change.
    Any tips on exhaust manifold as it's been slowly getting louder ever since I had my chain replaced.
    Also has the inlet manifold got it's own gasket like the throttle body as there's oil sitting in it that can't be doing it any good.
    Cheers in advance.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi H
    wiring harness of oil level control switch,starter motor,(disconnect battery first)
    remove starter,only 2 bolts.
    tightening torque for switch 18Nm
    starter motor bolts 40Nm
    inlet has 4 seperate gaskets.
    if exhaust manifold has been of and let hang on exhaust system the flexi coupling may have been damaged.if not it will been gasket or a cracked manifold
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
