Thread: Interior switch lights
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Default Interior switch lights
    Strange one this, being testing the various DRL settings in Tech 2. There are four settings in total, now on the 4th setting nothing apperared to happen, hence I then disabled the DRL again. When I turned the ignition off the headlights came on and I was unable to switch them off, after going through alll the settings again I eventually ended up disconnecting and reconnecting the battery and everything worked has it should again. Now I don't know if my mind is playing tricks on me but if somebody can check this it would be great, when I switch on the ignition and headlights are switched off I was sure that all the interior panel lights, steering wheel controls, electric window switches also illuminated but now they only illuminate if the external lights are switched on is this correct or should they be lit as soon as the ignition is switched on?
    Sep 2010
    Hartlepool
    All dashboard lights in my 54 reg vec come on, steering wheel etc when I put the key in but they go out again when I start the car unless the headlights are on, in which case dashboard lights etc stay on.
    HTH
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    If you activate DRL then they all will light up.. other wise they are off.
    Don't know if I'm just going mad, I was sure that before I started messing , err I mean testing the DRL settings that when the ignition was on and lights were off that the window switches illuminated all the time.
    Engine : 2.2 Direct
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    nope, only when sidelights are switched on.... Had the exact same problem when I was testing the DRL settings too.... Had to disconnect the battery after resetting the DRL back to off again...
    Thanks for that Ken, think I must be losing the plot.
    Cheers Plasma you've put my mind at rest
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    My interior lights and dash comes on when i open the car door after unlocking and then go off if i don't put the key in the ignition. then after inserting the key they come on again
  1. DIY Map lights, Interior lights Off button console?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 10:35
  2. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  3. Dash switch backlighting and interior lights not working...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 00:03
  4. Interior headlight switch with fog lights switches
    By merikiito in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th October 2008, 11:56
  5. 4 switch interior light
    By paulhb in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2008, 11:22
