Thread: Rattle, Knock & Dodgy Clutch Pedal - CDTI 120 - HELP!
    Birmingham
    Default Rattle, Knock & Dodgy Clutch Pedal - CDTI 120 - HELP!
    Folks,
    My cousin has a Vectra 2005 1.9 CDTI 120 and it has developed what appears to be a "knocking" sound from what sounds like the top of the engine?
    He also said that he notices that sometimes the clutch pedal seems like its slipping.
    My early diagnosis points towards the flywheel/DMF so I went and had a look and am hoping you guys can confirm details please.
    Randomly when the car is running there is quite a loud knocking noise coming from the engine and when I checked its like a loud rattle but not much of a tin sound, more a knocking.
    Anyway, when driving the car, the clutch pedal is fine but then intermittently when you change gear and release the clutch slowly it the pedal develops a ratchet like feel near the top and then as you are driving and release the throttle pedal and press the clutch slightly, it vibrates quite bad. Also, sometimes when changing the gear you get like a squeal or a squeak (very intermiitent).
    Anyway, so we parked up and the rattle/knock from under the bonnet was present so I rev'd it up and as the rev's went up it was knokcing slightly but as the revs drop the sound got louder. Then I got into the car and presssed and released the clucth several times and the sound was coming and going and getting louder and quieter!
    So.....am I looking at a flywheel?
    How much are we looking at £££ ??
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    ? anyone ?
    Bye bye Vec B
    - Hello Siggy!
    West
    It does sound like a dmf issue...
    You are looking at about £250 labour plus parts, i don't know about the 8v prices but Euro car part have the complete kit for the 16v for around £350 & they are LUK parts too
    Birmingham
    Are we looking at Clutch aswell or just the DMF?
    Bye bye Vec B
    - Hello Siggy!
    West
    the kit has a new clutch with it i think, always best to renew while your at it
  1. Clutch / Gearbox noise / rattle CDTi 150
    By Paul_B in forum Engine & Drivetrain
    Last Post: 1st March 2013, 17:21
  2. cdti clutch pedal spring
    By wirrallad in forum Engine & Drivetrain
    Last Post: 26th June 2011, 09:59
  3. Clutch Pedal Vibration - 150 CDTi
    By Hopewell in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 14:28
  4. Front suspension rattle/knock
    By damian s in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 16:47
  5. Rattle from clutch when pedal is pressed half way down.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2008, 17:33
vectra 1.9cdti 120 engine is knocking rattle on clutch
vectra c 120 cdti engine knocking
