Results 1 to 3 of 3
Thread: How To Check Throttle Position Sensor???
    Sep 2010
    Hartlepool
    Default How To Check Throttle Position Sensor???
    Hi,
    Does anyone know how to check the connection and wiring on the throttle position sensor on the accelerator pedal?
    I think this may be contributing to a problem I have.
    Thanks.
    Oct 2009
    Luton
    If you know someone with Tech2 then you could record some data from a drive. Or you buy a gauge, there are a few on the market not too expensive, I have a scanguage (see ebay) it plugs into the diagnosic plug (under the ashtray) and gives real time output from a number of sensors including throttle position.
    BTW the scanguage is EOBD compatible so won't work on the old 2.0 & 2.2 diesels.
    Sep 2010
    Hartlepool
    Thanks. I have a 54 plate 1.9 CDTi 150 and am keen to check this. The car is due a service (getting done a week on Monday) and, fingers crossed, that will solve the problem but I have read about other users with exactly the same symptoms as mine and they have checked the TPS.
    The car had a really bad episode of power loss this morning (I had to pull over twice, turn the car off and re-start it). After the second re-start, it was a little jerky then it was ok for the rest of the journey in to work. The other morning, I used cruise control for most of my journey and the problem didn't occur which is making me think it may be related to the TPS on the accelerator.
  1. throttle position sensor
    By Ryan in forum Engine & Drivetrain
    Last Post: 24th November 2010, 21:06
  2. Throttle Position Sensor
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 15:12
  3. Throttle Position Sensor...
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 16th September 2010, 20:51
  4. Throttle Position Sensor
    By Kristypie in forum Engine & Drivetrain
    Last Post: 9th April 2010, 21:14
  5. throttle position sensor
    By Morephun in forum Engine & Drivetrain
    Last Post: 3rd July 2008, 10:30
