Thread: New keyfob batteries
    Jun 2009
    Middlesbrough
    Default New keyfob batteries
    I have replaced my keyfob battery but it still intermitantly opens and closes the doors.
    Does it have to be re-coded or reset or something if the battery is removed and if it does how do you do it.
    Paul
    11 Post(s)
    If it intermittently works then it doesn't need re-syncing to the car. You only do that if it doesn't work at all.
    Does your spare fob behave in the same way?
    Jul 2009
    The Rift, Cardiff
    but when it does need resyncing use the key to unlock the drivers door.
    Jun 2009
    Middlesbrough
    Thanks for replies
    I will check the spare one but if I recall that was the same but I will check it tho.
    To re sync do I just fit the battery and then open and lock the doors or is just opening them sufficient?
    Paul
    11 Post(s)
    It should mention it in the handbook, but IIRC you also have to put the key in the ignition. On earlier Vauxhalls you had to turn the key to position two and press either of the fob buttons within something like 30 secs and the central locking would then activate to confirm syncronisation had occurred.
  1. Key fob batteries??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2012, 08:26
  2. Batteries
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 17:42
  3. Key Fob Batteries
    By kompkar in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 21:50
  4. Key batteries
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:01
  5. Car batteries
    By Ste in forum General Chat
    Last Post: 27th January 2008, 20:33
