Results 1 to 10 of 13
Thread: key fob not working
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default key fob not working
    hi my keyfob only works when wants too has anyone had this before pls and any idea how tooo fix it,i bought new battery so it aint that
    regards
    Full Member Big Sig's Avatar
    Does it always light up? Could be interfearence from somewhere as mine used to play up in tesco's as it was close to a mobile phone mast.
    Halstead, Essex
    What kind of fob is it? If it works from time to time you might have to clean the battery contacts.
    Nov 2009
    south wales,Cwmbran
    it always lights up
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does your other fob work?
    Light up? mine don't have a light on either of them.
    preston
    yes clean the contacts with contact cleaner from maplin or soemthing similar - worth the money as it can be used fror all manner of electrical surface cleaning
    then at a guess - try another battery
    sometimes they are faulty from the off.
    other than that
    you can reprogramme the fob
    I think it involves accessing the door with your key. I'll try to find the link later today
    unless someone else beats me to it......
    cheers
    Nov 2009
    south wales,Cwmbran
    ok mucker ta
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the other fob works properly, then you know the problem is with the fob and not the car. If your other fob also works in the same intermittant way, then the problem way be with you car and not your fob.
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by Ste View Post
    i aint got another fob muck?
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    i had this problem afew days ago.even though the light was still working on the fob.i changed the battery and still no different untill i started the car up with the key.ive not had any problems since. luke
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
vectra c key not working
vectra c key fob not working
