Thread: Cdti 150 6 Speed with a Snappy Clutch ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Cdti 150 6 Speed with a Snappy Clutch ??
    55 plate Cdti 150 Six Speed.
    The clutch is extremely light & quite snappy, You have to be really steady with your clutch control or you are off with a bang .. The bite point is fine & there is no crunching, Grinding or slipping .. Just v little resistance from the pedal ... My initial thoughts are the Slave cylinder !! ??
    The flywheel is also quite quiet with noe of the usual Dmf rattles to be heard ...
    What do you all think .. I will at some point just bleed it first (Cheapest Method first) to see if that makes any difference ..
    Dean
    Nov 2007
    Staffordshire
    Bump
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Air in system maybe ? Have you checked for leaks
    Irmscher Insignia CDTI 130
    Nov 2007
    Staffordshire
    Quote Originally Posted by bigmac View Post
    I have had a peek as best as you can & cannot see any signs of leaking .. but i will bleed it at some point to see if things improve at all ..
    Dean
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    At least you don't have an aggressive clutch.
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    He does have an agressive clutch he said? Perhaps the DMF has seized, that would reduce the damping of transmission shock loads conciderably in theory.
    Nov 2007
    Staffordshire
    Quote Originally Posted by john_k_sri View Post
    Do you ??
    Nov 2007
    Staffordshire
    Quote Originally Posted by nutron View Post
    I did think about that , But compared to another it just feels very light (not as heavy/hard to press) If the Dmf is seized surely clutch pedal feel would still be the same/similar between vehicles, The feel is also the same with the engines not running !!!
    Dean
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    By aggressive I mean tight and 'heavy' , as on the little Fiat I had as my first car, very little travel to be bite point, as opposed to light and smooth which has been the case on all 3 Vec 'C's I have had.
    Mine goes off with a bang if I'm too quick off the mark in 1st and 2nd, but only in the dry. In the wet I spin the wheels and torque steer, as there is no TC, unlike on my previous 2.0T pre-facelift.
  1. Gear selector or clutch 6 speed Turbo
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 1st September 2011, 20:57
  2. 3.0 cdti clutch. Fits in 1.9 cdti?
    By Zampus in forum Engine & Drivetrain
    Last Post: 16th February 2010, 14:22
  3. CDTI V6 Auto 6 speed Help
    By zimzunga in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 18:34
  4. Top speed in a 1.9 CDTI
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2007, 20:08
  5. V6 CDTI top speed?
    By diesel dog in forum Diesel Engine related
    Last Post: 4th August 2007, 00:04
snappy clutch
