Results 1 to 10 of 14
Thread: Front end wobble
    Regular Member squekey's Avatar
    bedfordshire
    Default Front end wobble
    afternoon people
    I have been experiencing some front end wobble in my 2004 vectra 2.2direct sri, i have had all the wheels rebalanced to eliminate that one, below 40mph cars is fine soon as i go over 40mph with the accelerator down i get the wobble if i release the accelerator then the wobbling stops? i have been told this could be caused by a bent driveshaft or the inner cv joint is on its way out. Does anyone have any knowledge on this or had the same problem, also does anyone know which drive shaft the 2004 2.2sri has as i been looking on ebay and there seems to be a few for the 2.2 vec c's phoned my local vx up earlier for a price on a brand new drive shaft and they said it was £500+ so i will not be getting one from there lol.
    any comments will be much appreciated.
    Chris
    bedfordshire
    anyone?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Definatly sounds like a knackered drive shaft, worth sourcing one from scrappy
    bedfordshire
    nice one for the reply mate, is it the o/s/f that would normally go? i have seen a few on ebay but unsure which one my car has as there seem to be a few different ones marked up as 2.2 vec
    does anyone know which one of the belows would fit my 2004 vec 2.2sri direct if that makes any difference
    (1)would it be this one?
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item5ada68ba30
    (2) or this one?
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item2c55e0ad1a
    (3) or this one?
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item255d439f5f
    im getting confused as to which one would fit my car as you can see from the above links there seem to be a few available????
    Your help on this is much appreciated.
    bedfordshire
    anyone know what drive shaft i will require?
    bedfordshire
    evening all
    Just wondering if anyone can help with the above as i am looking to get another drive shaft soon as but aint sure which one will fit my car.
    would the wobbling be mainly down to o/s drive shaft or both? and also are they easy to change?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Best person to ask would be rushy, I know that the 2.2directs had a 6 speed box so not sure if the drive shafts were different. Only difference with the last one is that it comes with the extra support bearing thats on the drivers side
    bedfordshire
    ok nice one John, mine is a 5speed will send rushy a message.
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by squekey View Post
    afternoon people
    Chris
    Hi Chris! its Craig [omega63] yer!!! sounds the same as mine and i am pretty sure without a doubt its the inner CV joints. When i worked as a techniction for Vauxhall there was many recall and rework notices for the vectra c in one month i replaced under warranty 5 sets of complete driveshafts on vectra c,s. Mines a 3L V6 CDTI and i,ve and i have been quoted £400 each driveshaft, i,ve been told that on mine the inner CV joints are the same as the 1.9 CDTI, sorry cant help you with yours but as like mine you maybe able to match up with another vectra c.......
    bedfordshire
    nice one for the reply craig, yeah i got quoted £550 from vx for a new o/s drive shaft so thought i would by second hand just unsure as to which drive shaft is for mine, im gonna do my track rod ends and anti roll bars first as i believe these are an easy job to do myself if im not mistaken.
    i had had a quick look on the net but cant seem to find anywhere selling the inner cv joint? does anyone know where i can get one from as vx wanted £110 for it.
  1. Wobble!
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2011, 12:20
  2. bum wobble
    By Al 22 dti in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 12:47
  3. Wobble between 20 and 30 mph
    By Tigger in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2011, 00:28
  4. Wheel wobble at 40 to 50 mph
    By iwoo in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2009, 15:56
  5. Signum front wobble
    By Agoogy in forum Suspension, Wheels & Brakes
    Last Post: 20th November 2007, 18:12
vauxhall zafira 1.9 cdti elite 2010 front end wobble
2010 vauxhall zafira diesel wobble from front end
vectra c wobble
2004 vauxhall zafira front wheel wobble
vectra c 1.9 cdti drive shaft site:www.vectra-c.com
vectra c wheel wobble
