Results 1 to 3 of 3
Thread: Headlight Cluster
    Jul 2010
    Default Headlight Cluster
    How do I remove the nearside Headlamp Cluster ? I have found 2 bolts which make it loose but is there a 3rd (or 4th, etc) fastening that prevents me from removing it. (The reason for wanting to do so is that is is pointing skywards !)
    Sodding Typical on Sea
    You can adjust the lights without removing them, it is the inner of the two adjusters seen under the slam panel a 5mm alan key fit
    If you do wish to remove the light then take the front bumper off, its the easiest way as there is a third 8mm screw under the outer edge
    Jul 2010
    Thanks Derek, Will have a look in daylight tomorrow.
  1. car cluster repairs
    By the fisherman in forum General Chat
    Last Post: 15th June 2012, 10:38
  2. instrument cluster
    By waky in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 00:31
  3. instrument cluster
    By veccyv6 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2011, 19:03
  4. Instrument cluster
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2008, 20:02
  5. Headlight/Fog light/Dimmer Cluster....
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2007, 08:23
removing front light cluster vectra c
