Results 1 to 10 of 11
Thread: wear in inside edge of rear tyres
    Sodding Typical on Sea
    Default wear in inside edge of rear tyres
    Can anyone advise the likely worn cuplrit as I plan to get it done while I still have some warranty left to call on
    Sadly it is a normal wear pattern on the Vectra C
    The only solution is to swap tyres rear to front as they wear
    I had GoodYear do some tests on a full set of tyres on my own car and could find nothing effective to fix this
    Cool, many thanks I thought I would check here before calling E/H
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Have you checked the upper control arm bushes for wear derek?
    It was in Evans Halshaw they noted the wear but didn't draw my attention to anything that was replaceable, I will wait for the rain to go then have a prod about under her bum
    Apr 2008
    leicester
    you need to get four wheel tracking done on it had mine done and its as good as gold
    Quote Originally Posted by micks edition 100 View Post
    It had that I believe when the front strut top mounts were changed so should be good to go then
    Regular Member DaveW555's Avatar
    Cannock
    You can adjust the camber by turning the adjuster bolt/washer on the suspension arm, This is my planned fix to stop it happening on mine as I'm sick of the back tyres wearing unevenly, its a bit trial and error to get it spot on but if you use a spirit level on the wheel, you'll know when its vertical by reading the bubble. Not exactly scientific but I've used this method on other vehicles with success so I cant see why it wont work on a vectra.
    West
    get the rear upper arms checked, although the vec C does have neg camber it's usually the worn bushes in the arms which causes the tyre wear
    Regular Member watchman's Avatar
    Apr 2009
    Leeds
    Engine : Z28NET
    Mileage : 75000
    I had this problem, and got a full Hunter wheel alignment done.
    It confirmed that the camber was out on both rear wheels.
    But they said there is no guarantee it won't need redoing - potholes, speed bumps ......
  1. Rear tyre- inside edge is stepped and uneven?
    By Craig1985 in forum Suspension, Wheels & Brakes
    Last Post: 31st July 2012, 10:13
  2. Very fast wear rear tyres
    By kantimpalo in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2012, 18:34
  3. Tyre wear in rear inside edges
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2011, 14:38
  4. rear tires destroyed on inside edge
    By MRS Wez in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 19:09
  5. Help! Front tyres, inside wear!
    By Wiggles86 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2009, 09:02
vectrea rear tyre inside edge wear
