Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: why is it hard to change gear??
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Default why is it hard to change gear??
    hi all first of all everything happening today not good any way on way home today was overtakeing a car went from 2nd to 3rd and 3rd grinded never done that before fort must be me but it doin it no every time chance in to 3rd the only way to stop it was to change wait a sec then select 3rd fine but ehy is it doin this (had new flywheel master and slave etc in may it happened then once but never thats it) any help lads would be helpful at this rate ill be doin this very soon
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    mine started doin that it was the 3rd gear syncro eventually u will loose third gear.
    i had to replace the gearbox.
    Sep 2010
    in a box
    can i start digging my grave now then was it hard to find 1st when you started off or just 3rd cant be doin with new gear box that will just wipe me out really
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Oh god... I'm not crunching gears yet but I know for a fact my synchro's are going.
    A replacement gearbox in Aus will essentially make it a write off for how much its going to cost me
    Sep 2010
    in a box
    it only crunches if i race from 2nd to 3rd gear no other gears do it maybe a bit hard to find 1st when i start off thats it but if it a gear box im goin to just die dont need this now really dont but thanx
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    you have to press that pedal on the left next to the brake... It usually stops the crunching
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by bangty 1 View Post
    That's the classic symptoms of a known fault with the F40 6-speeder. It had too much oil put in it at the factory - 3.2 litres. Taking it out and putting in 2.4 litres will cure it. Follow this How2, and also add in some Molyslip gearbox protector grease and it'll drive like new:
    http://www.vectra-c.com/forum/showthread.php?t=114196
    Sep 2010
    in a box
    but it had a new clutch in may and the gear box oil was changed then do you think i should chance it well whats worse that can happen lol thanx agen
    I'm running an F35 5 speed.
    Anyone know if theres a known fault? Or is it just wear and tear?
    Sep 2010
    in a box
    nice how to mate will be on that tomo top man thanx
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Is it hard to change the brake callipers?
    By claudiu666 in forum Suspension, Wheels & Brakes
    Last Post: 3rd February 2012, 15:23
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. Is it hard to change oil on 1.9 sri 150
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2008, 00:29
  5. How hard is to change pads
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 8th September 2007, 22:48
