Results 1 to 10 of 11
Thread: timing belt 1.9 cdti
    Regular Member fingers66's Avatar
    Carpe Diem
    Default timing belt 1.9 cdti
    After bumming to my pals how good my vec is, I pulled away from home then it stalled, tried to start it twice.... nothing..... I checked the usual, then took cover of timing belt, the belt is still on, just all the teeth have worn right down..... how much damage would this have done and how much will it cost to be repaired.....1.9 cdti 150 68K miles on clock .......
    Sodding Typical on Sea
    You need to establish if the rockers are all smashed as they should let go first before major damage.
    If this is the case you need a set of them plus a timing belt and tensioners plus a water pump.
    What age is the car and does it have a full s/h as it really should be a warranty job as the change intervals is 80,000 miles.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i thought the belt was a 100k
    CDTi is 80K in the service books now, but 68K that's scary sh**!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Possibly the water pump seized, hence the worn teeth?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The water pump runs on the back/flat side of the belt so as i found when my pump was seizing to the point the engine was hard to turn over by hand & the pump was squealing & squeaking, but the belt was only slightly rubbing on the flat side, the teeth were perfect, mileage was 63k from new. so i would say the tensioner has gone allowing the belt to run slack therefore moving back & forth on the gears.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by Derek Mc View Post
    As you say it could seem scary but looking at my belt when it changed it at 63k after pump failure, it was in perfect condition apart from wear on the back/flat side due to the seizing pump. The tensioner on mine seemed in perfect condition.
    Are you VXR Enough
    13 Post(s)
    i just checked my service book and its says ten years and a 100k i phoned vx too and they confirmed
    Jan 2010
    Sheffield
    Ive just had mine replaced by a friend who works for Vauxhall, new belt, rollers , tensioners, water pump, alt belt, software updated etc, i was on 96k miles .... Glad its all done now as a friend at work had his water pump seize on the same engine on 90k
    Regular Member scottyd's Avatar
    paisley
    get onto vhall cust services that is unaceptable mate
  1. where to get 19 cdti 150 timing belt kit?
    By ronnie63 in forum The 'Off Topic' room
    Last Post: 25th August 2012, 17:24
  2. 150 cdti timing belt again
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 09:33
  3. Timing belt on 1.9 cdti 150?
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 10:35
  4. cdti 150 timing belt kit, where's best to get it from?
    By veralum in forum Engine & Drivetrain
    Last Post: 19th January 2010, 18:32
  5. Timing Belt CDTi 120
    By ROB WOODHOUSE in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2006, 23:25
