Thread: oil and swirl valve
    Regular Member POAH's Avatar
    Glasgow
    Default oil and swirl valve
    went to take off my EGR valve to give it a clean and found my swirl valve bar had come off and the area around the valves covered in grimmy oil. is it normal when the bar comes off for there to be this grime or am I looking at something more nasty than glueing the bar back on?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    No wasy way m8 but it is new manifold time . You could try and put it back on but I don't recommend as you could end up knackering the drive module too adding more to the cost. This is because the valves will not be moving and all the oil and dirt form to 'jam' the valves solid. If you successfully re-attach the swirl rod it could cause the drive module more stress and possible failure.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    EVERYWHERE
    Some run their engines without the swirl bar, but it's in the lap of the Gods as to what position the flaps have stuck in. It depends on where they have stuck as to how well the engine continues to run.
    A crap design initially. New ones have no problems....unless you know otherwise!
    Kent
    Where abouts are these swirl valves?
    Regular Member Craig1985's Avatar
    harwich essex
    How much is a new manifold roughly at a main dealer, mines gone too
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    At a vauxhall dealer for manifold and fitting your looking at 650 quid
    Just the manifold part price is roughly 230-300 depends on where you buy
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. Swirl Valve
    By parsco in forum Engine & Drivetrain
    Last Post: 29th April 2009, 20:47
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
