Thread: Electric tailgate opens itself
    NORWICH
    Default Electric tailgate opens itself
    Hi got a 56 plate Vectra 1.9 CDTi Estate with the electric tailgate feature. When i go to unlock the car, the tailgate opens itself every time. Also if i leave the car unlocked it will open itself within 2-5 minutes. It closes on the fob exactly as it should but the only way to keep it closed is to lock it.
    Sounds like a fault with the catch somehow. Anybody encountered similar??
    11 Post(s)
    I take it the button on the drivers door isn't stuck down?
    NORWICH
    No mate
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    does the catch actually open the boot?
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Does it do the same on both fobs? I had exactly the same issue and it was the boot button on the three button fob that was at fault. If you've only got the one fob take the battery out and shut the boot and see how it goes.
    WGAF#5
    its probably the boot release solenoid (on the tailgate switch) sticking or shorted out
    Aug 2010
    Sweden
    Hi
    I've had the same fault on my vectra. The problem was solved after fixing the tailgate switch. The problem is the little springball inside the switch that get rusty. Some WD40 and new grease worked for me. I also seald it with bathroom silicon.
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by tmi03mpn View Post
    Hi
    I just had exactly the same problem with my power tailgate. Thanks to this info in this thread, I have now repaired it with electric cleaner and WD40. And now the tailgate switch is like new and no open itself issues.. On mine the "ball" was fine. It was the "plate", that you press, that couldn´t move freely enough in the plastic housing.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    good to know
  1. Electric Tailgate Faulty????
    By bafoo in forum Vectra C / Signum Troubleshooting
    Last Post: 28th July 2013, 09:11
  2. Electric Tailgate Shut Button
    By phill77 in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2012, 23:40
  3. Retrofitting an Electric tailgate on SIGNUM!?
    By cocun in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2011, 23:57
  4. Estate Electric Tailgate
    By chaddopete in forum Bodywork & Interior
    Last Post: 3rd August 2011, 16:21
  5. Electric tailgate retrofit?
    By Scalesy in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2008, 21:46
https:www.vectra-c.comforumshowthread.php119078-Electric-tailgate-opens-itself
vauxhall astra tailgate
astra h boot opens on its own
why does my vectra electric boot keeps opening
2006 astra design boot keeps unlocking itself
vectra c tailgate opens by itself
vauxhall astra 2005 boot opens on its own
vauxhall vectra estate electric tailgate problems
