Thread: Brake pipes to replace
    Jun 2009
    Middlesbrough
    Default Brake pipes to replace
    Hi
    Have to replace my brake pipes, left and right sides, front to rear on 2.2 DTi SRi 2003.
    What size pipe and fittings are needed and any tips would be very welcome if someone has done this before.
    Paul
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    3/16 mate
    Have fun doing the nearside rear wheel as the pipe goes over the fuel tank. Oh and have the engine running when bleeding the brakes so as not to damage the abs system
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    is that the recommended method, engine running? Useful to know as I will hopefully changing my front calipers this weekend and all four hoses are being uprated to Goodridge braided jobbies..
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's the best way i've found to get a good pedal. Just remember you have full servo assistance though so be gentle
    Jun 2009
    Middlesbrough
    Default Rear brake pipes
    Thanks for your replies
    I have looked at the pipes today and they look a bit of a ****** so will leave until they fail MOt then get garage to do them.
    As for bleeding the brakes, which I will have to do when I do my rear brakes, is the reason the engine is running while bleeding because the vacuum for the servo is fed from a pump which needs the engine to be rotating for it to work correctly, normally the vacuum is fed from the throttle housing isnt it and diesels dont have a throttle as such, or is my understanding ********.
    Paul
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No the reason for it running is so that the ABS pump is active, all the vacuum pump does is run the power assistance, a petrol will only have power assistance if it's running too
    Jun 2009
    Middlesbrough
    I see.................thanks for that John
    Paul
  1. Replace 2.2DTI intercooler pipes?
    By kenno31 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2012, 11:14
  2. Brake Pipes
    By st2malo in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:46
  3. brake pipes
    By DTi Elite in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 22:00
  4. Brake Pipes.
    By djveccy in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2010, 00:42
  5. Brake pipes pre facelift...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2009, 23:01
