Thread: Auto Dip Mirror
    Jan 2010
    York
    Default Auto Dip Mirror
    I'm not sure mine actually works - anyone able to show me a surefire test, please?
    TIA!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what mirror.. inside?
    let it be dark enough.. then hold a little light infront of the sensor (same side as mirror) then it should DIM.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sit in the dark and point a torch from the back seats at it, It should gradually dim down
    Jan 2010
    York
    Tried that and really can't see if anything happens!
    Could be my Specsavers, I guess..........
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    you will notice a blue/green tint in the reflection of the light you are pointing at it
    Engine : 1.9 CDTi
    Is there not a sensor also on the back of the mirror?
    If there is during the day cover up the back sensor (Windscreen side) and it should dim.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Switch ignition on ... headlights on .... cover the sensor facing the windscreen (finger is fine)...... shine torch/lamp onto the sensor below the mirror face.... mirror should quickly go deep 'bottle green'. If fitted, you should also notice amber light on on underside of mirror unit, pointing straight down at gearstick.
    Turn off torch or remove finger from front sensor and the glass should return to 'white'.
    Why bother with a torch. The simple act of switching on the interior light is enough to flood the sensor.
    Engine : 1.9 CDTi
    Interior lights and putting the car turns the auto tint off (I think)
    Quote Originally Posted by lee gsi View Post
    Only if you open a door will it disable the auto tint (or if you were to select reverse gear). Switching the interior light on via the on/off buttons doesn't disable it.
  1. auto dim mirror
    By Ray_Ray280 in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2011, 00:31
  2. For Sale: auto dim mirror
    By daddyjay in forum Parts for sale
    Last Post: 5th June 2011, 18:00
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  5. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
