Results 1 to 10 of 28
Thread: Whats this light?
    Regular Member Mark1892's Avatar
    North East
    Default Whats this light?
    I'm presuming its the engine management light, an amber engine symbol on the r/h side of dash. No difference in engine performance, oil and coolant levels are ok. I havent got a code reader so would have to pay someone to check it out. Is there anything else obvious i should check first?
    Also seen code readers on ebay for about £30, they do the job or are they tat??
    2003 1.8 LS btw.
    Mileage : 000
    If I am correct the "engine symbol" is when there is something wrong with the emissions.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    does it not come on during regen ?
    Irmscher Insignia CDTI 130
    North East
    Quote Originally Posted by bigmac View Post
    Think i need to read the manual when the wife gets back with the car.
    Whats the regen?
    North East
    Right, just checked the manual and it is the exhaust gases light - fault in emission control system. permitted emission limits may be exceeded.
    I also done the pedal test and i think i got two codes.
    10 flashes normal pause then 1 flash then normal pause then 7 flashes normal pause then 10 flashes then a longer pause then 10 flashes normal pause then 1 flash normal pause then one flash normal pause then 10 flashes. ( 10_1_7_10_____ 10_1_1_10 ). can any one help or give link to relevant codes list? thanks
    are the codes P0170 and P0110??
    Regular Member Psykadelik's Avatar
    London
    Here you go mate!
    P0170 - Fuel Trim Bank 1
    P0110 - Intake Air Temperature (IAT) Sensor Circuit
    http://myweb.accessus.net/~090/dtcobd2p.html#pow
    North East
    Quote Originally Posted by Psykadelik View Post
    Here you go mate!
    Cheers mate, do you know if they are linked in anyway, I.E. one cause the other??
    London
    The Intake Air Temperature (IAT) sensor resistance changes in response to the intake air temperature. The sensor resistance decreases as the surrounding air temperature increases. This provides a signal to the PCM, indicating the temperature of the incoming air charge.
    The following symptoms can be caused by a faulty IAT sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit.
    Possible Causes
    - Intake air leaks
    - Front Heated oxygen sensor may be faulty
    - Injectors may be faulty
    - Exhaust gas leaks
    - Incorrect fuel pressure
    - Lack of fuel
    - Mass air flow sensor may be faulty
    - Incorrect PCV hose connection
    So the answer is YES, they can be related. Possible Causes of P0170 - Intake air leaks also if there is a leak, this may also mean that is might be affecting P0110 as it can't give correct readings
    But hey, I'm no guru
    North East
    Possible Causes
    - Intake air leaks
    - Exhaust gas leaks
    - Lack of fuel
    maybe not guru but definetly a star just realised that it had a cam belt and kit fitted last week, now wondering if all intake hoses/pipes etc are back in place correctly?????
    London
    Quote Originally Posted by Mark1892 View Post
    Yeah you might wanna check all connections again because these sensors are very very sensitive and this can be a pain sometimes but on the otherhand can be very useful
  1. Whats this light
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2014, 18:10
  2. Whats this light
    By MARKPRIOR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th February 2011, 14:35
  3. Whats this light? (i'm new here!)
    By Munter in forum Engine & Drivetrain
    Last Post: 20th October 2007, 19:00
  4. just noticed a light.. whats it for ? :)
    By Cerealuk in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 13:22
  5. whats this warning light?
    By m20_swe in forum Engine & Drivetrain
    Last Post: 17th October 2007, 00:57
