Thread: Calling you clever engineering types...advice needed
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Default Calling you clever engineering types...advice needed
    Hi all,
    Please help The peeps who live above me love using thier tumble dryer and it send a low pitched hum all through my flat
    It must be some sort of weird frequency as it seems to wake me up and it travels all through my place.
    They have tried putting doubled up carpet squares under the legs but it hasn't made a bit of difference.
    I can turn my TV up and I can still hear it. What else can they try to stop the "buzzing"? they have two young children and with the weather turning this is going to be on all the time
    Cheers all
    Jon
    Huddersfield
    You should be able to get some form of anti vibration (av) isolator (can't think of the name). Air conditioning units usually use them if on roofs.
    Sodding Typical on Sea
    You need to get cork tiles to isolate it but it also needs to be away from touching walls, and such as the vibrations can permeate so easily.
    Seer Green, Bucks
    Quote Originally Posted by Derek Mc View Post
    That sounds doable as its under a kitchen worktop so space is limited
    Keep them coming
    bRISTOL
    as long as they are satisfied it is not a bearing fault teko pads are the answer should absorb vibration
    Huddersfield
    Seer Green, Bucks
    Quote Originally Posted by Paulrushton View Post
    Now that seems an ideal solution. I will show the neighbours and see what they think.
    Regular Member Andoo's Avatar
    Sep 2010
    Highlands
    How old is the dryer?
    Could be a bearing on the way out.
    Seer Green, Bucks
    Quote Originally Posted by Andoo View Post
    I'm not sure mate, I have a discussion on another forum and it seems the vibration of the motor could be tune with the resonance of the brickwork as the "buzz" travels all through my place
    Looks like it's going to be a ****** to sort out
    Jon
  1. A clever bunny needed please!
    By blue estate in forum Photoshop section
    Last Post: 15th March 2012, 10:36
  2. Social Engineering...
    By spoons in forum General Chat
    Last Post: 25th January 2011, 16:25
  3. Engineering/University advice wanted
    By Graeme01 in forum General Chat
    Last Post: 10th December 2010, 23:41
  4. Calling all mechanics! Knowledge needed!
    By Giw in forum Engine & Drivetrain
    Last Post: 11th June 2010, 09:01
  5. Engineering the way it should be
    By SignumPhil in forum Comedy & Humour
    Last Post: 6th March 2009, 20:00
