Thread: 2.2DTi Y22DTR vacuum hoses scheme
    Sep 2010
    OX
    Default 2.2DTi Y22DTR vacuum hoses scheme
    Hi everyone,
    I own 2003 Zafira. Having problem with power loss when driving... Ive cleaned EGR, boost sensor etc... Now I want to check all the hoses but cant find any scheme of them.
    Many thanks
    Regular Member Dazzy2006's Avatar
    Notts
    Sep 2010
    OX
    Not bad, but Zafira seems to be a little different...
    Full Member Big Sig's Avatar
    have a look on AOC and AON as iirc they both cater for the zaffy
    Regular Member Innes's Avatar
    Plymouth
    Post a pic of your engine with the plastic cover off and we'll point it out to you :-)
    Sep 2010
    OX
    Here you go... Hope you find some mistake... Actuator on the turbo is working - tried it with my mouth.
    Plymouth
    Definatly different from my 2.2dti. Think you must have the older version. There seems to be a lot more rubber connectors.
    To be honest it doesnt sound like you need our help as it looks like you have found the entire layout of your vacuum pipes.
    To replace them start from the turbo and replace each section at a time. Looke like you'll probably need about 4 meters of the silicone hose.
    Sep 2010
    OX
    Problem solved... Two hoses were wrong - green marked vs. blue marked were swapped wrong...
    Now the car goes like it should...
    Cheers!
  1. 2.2 DTI vacuum hoses / pipe
    By Alistair123 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 15:50
  2. 2.ot boost hoses intercooler hoses
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 23:21
  3. y22dtr egr
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 27th April 2011, 20:26
  4. 2.2dti vacuum pump leak
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 15:07
  5. upgrading vacuum & turbo hoses
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2010, 16:44
opel vectra c 2.2 dti vaccum installation
vacuum lines 2.2dti
2.2dti 92kw vacuum hose
zafira 2.2dti wiring diagram
opel vectra c 2.2 diesel vakum
y22dtr silicone hose
y22dtr remap
vectra 2.2 dti vacuum diagram
opel 2.2 dti vacum conections
vauxhall vectra 2.2 dti vacuum explained
y22dtr 2.2dti схема вакуума
vauxhall vectra c y22dtr
turbo hoses vectra c
vacuum pipes for vectra 2.2 diesel
vectra c dti vacuum pipe diagram
vectra vacuum pipe diagram
2.2dti vacuum diagram
Signum vacuum pipes diograme
vectra c 2.2 dti vacuum
vectra c 2.2 dti vacuum pipes
vacuum hose diagram vaxhuall 2.2 dti engine
vacuum pipes scheme 2.2 dti engine
2.2dti engine vacuum hose size
opel vectra 2.2dti vacuum scheme
vacuum lines 2.2 dti
