Thread: which wheels???
    Jul 2010
    lancs
    Question which wheels???
    anyone know which wheels these are? I need some spigot rings for them. one place told me they might be TSW Pace alloy. But i'm not sure as they don't have the TSW centercaps, just plain chrome. i wondered if they could be cheap relicas??
    http://www.caraudioni.com/alloy-whee...set-of-4-p-449
    Attachment 35286
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Id certainly say they look like TSW Pace ones to me. Look at the position of the valve and the step from the outer rim to the inner rim holding the valve looks the same if not very very similar to me. If you can measure the hub mount where the sigot ring goes you should be able to match that up with the ones from TSW.
    Aug 2010
    Antrim
    On a similar note. I saw a 08 Vectra 1.9CDTi SRi the other day with what I would say were 18 inch alloys, with a VX centre cap, but they were not standard SRi ten spoke or 19 inch snowflakes. I didn't quite get the spokes counted before the lights changed but they were either 18 or 20 spoke. They looked good, which is what attracted my attention. Anyone know what they might be?
    Jan 2010
    glasgow
    all u need to do is go to a local alloy wheel seller ie motor shop or the likes take 1 with you and tell them your wanting spigot rings to fit you vectra i take it its a vec there going on to and they should have a set
    Sodding Typical on Sea
    Another spigot fix, and one I particularly like
    pen a can of Lager, and consume to the preferred choice of entertainment, being Football, Motorsport, etc
    When empty cut said can into 10mm thick strips around the diameter wrap around the hub.
    Hold in place with duct tape.
    Replace wheel.
    Admire handywork and for the sake of science explore if a second can of said brew tastes as good as the first as this wheel changing malarky is darn thirst work!
    Seriously however it is a good temporary fix to get rid of the wobbles and allow you to locate the correct size spigots
  1. Structure wheels (Steel wheels that look like alloys)
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 21:24
  2. Replies: 18
    Last Post: 7th February 2012, 12:25
  3. Replies: 2
    Last Post: 17th November 2010, 22:45
  4. SIGNUM ELITE WHEELS TO VECTRA SRi WHEELS
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 12:09
