Thread: is any stereo gonna fit?
    London
    Default is any stereo gonna fit?
    Hi
    Im on my 2nd vectra this one a 54 plate life. It has the CD30 unit built in. However it dont work. well it works from the steering wheel controls but not from the actual unit. so I cant eject the cd or anything that bass adjustments.
    Anyway I want to buy a new stereo and my question is can I buy any stereo do they all fit and how to i cover up the gaps left putting a smaller stereo into the vast gulf that the CD30 currently occupies. Lastly will my built in display for the CD30 and steering wheel controls work with a new stereo. Or shoudl i just buy another CD30 or later upgrade?
    Thanks for you time and replies. (hopes)
    Aug 2010
    Antrim
    You can buy double DIN stereos that would fill the hole (but very expensive) or you can buy a standard one and an adopter that would give you a little storage shelf below the stereo. The screen will work for fuel info etc, but you can't change the clock (or zero stop watch etc??) with a 3rd part stereo. Still if your one is duff you probably can't do that in anycase. To buy a new CD30 or other VX stereo, it is my understanding that you need to replace the screen as the stereo and screen unit are permanently paired. All in all a pain in the butt.
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    How you describe your fault tells me there may not be much wrong with it.. I'd try fixing it.. It might have been fiddled with before, there may just be a disconnected little internal ribbon cable that connects the fascia panel controls to the rest of it..
    Regular Member Iezzi-martin's Avatar
    Jul 2010
    Birmingham
    Hi mate yes you can put almost any one in you like you will need to buy a face plate tho as if u put a single din radio in it won't fit I changed mine easy to do think there maybe a how 2 on here tho best to buy the plate off eBay as they are the cheapest ones an match well
    Sodding Typical on Sea
    If you want to keep it stock looking I think there is a CD30 and screen for sale on here that should plug'n'play?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like there is a dodgy connection between the facia and the stereo unit, worth having a check
    As for another stereo you can fit nearly anything into the Vec with it having the double sized apeture
    Dunstable
    http://www.vectra-c.com/forum/showthread.php?t=117536 And as john says, could be a loose front panel or dodgy connection thats causing the problem. Worth whipping the stereo out and having a look
  1. Calling ICE/stereo experts.. Dvd/stereo, will this fit in my Pre-face Vec C Gsi?
    By TAB in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 13:20
  2. gonna try a ps3 now
    By rickeys16v in forum Games Room
    Last Post: 10th December 2010, 23:33
  3. V6 Its a Gonna...
    By Gazza90000 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 23:27
  4. Factory fit stereo to ordinary size stereo
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 12:24
  5. OK, Now your gonna think I am really mad...
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 08:44
