Thread: new ignition car wont start problem
    Regular Member bighammerfan's Avatar
    hillingdon
    Default new ignition car wont start problem
    I have just replaced my ignition barrel with an identical one from vauxhall. Now the car turns over but wont start and the spanner light is on. any ideas please ?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    May be cim. Try pedal method to read error code.
    hillingdon
    Im not sure what you mean. pedal method ?
    Regular Member LADmachining's Avatar
    Hampshire
    Have you got a new key, or are you using the original key?
    If new, then the key contains a transponder chip which must be programmed to the vehicle before the engine can be started. The management light will be flashing with the ignition on if this is the case.
    Or you can try and swap the transponder or key blade from the old key to the new one.
    hillingdon
    sorted thanks mate
  1. Replies: 3
    Last Post: 5th January 2012, 19:15
  2. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  3. Poor start up on ignition
    By JJGSI32 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 22:17
  4. 2.0 dti wont start
    By dti111 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2010, 02:12
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
