Thread: Removing Radio cd30 and clock display
    Sep 2010
    Bristol
    Default Removing Radio cd30 and clock display
    Hi,
    Is there an easy way to remove the radio cd30 and the clock display on a 2006 Vectra C?
    The radio is easy of course, just woundering the best way to remove clock.
    Many thanks
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    remove dash strip, remove the 4 screws that holds the vents and clock.
    Then on the back theres 4 small screws that hold the clock to the vents.
    Jul 2012
    Essex
    Hi all,
    Just seen this in the search.. I have been given the chance to take out the Clock display that the CD30 has standard and replace it with a replacement screen, the part number is -
    13178765.
    Just wanted to check that this is compatible with my CD30? And if it is easy to replace?
    Cheers in advance..
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes it is a Vectra-C / Signum Full CAN Display
    EPC4 says
    Part Number= 13178765
    Catalogue Number = 12 36 727
    Description = UNIT, DISPLAY, MULTI-FUNCTION INDICATOR, GRAPHIC INFO - MONOCHROMATIC (IDENT SD)
    Chassis Number range = 51000001- (approx 2005 to 2007)
    but this will fit all models of CD30.
    Fitting is easy, however the tricky bit is the divorcing and pairing up procedures, which can normally be done by your dealer, using his Tech 2 programmer.
    Both the displays, and your head-unit will need to be divorced, before the new display can be paired to your head-unit.
    Jul 2012
    Essex
    Thanks for your reply Robsey. I will run the screen down to my local dealer.. After speaking to him, he said he can do this process for £30.00? Does that sound about right?
    Cheers.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    £30 is very cheap - most charge nearer to £80 - eek
    One thing I do say is ensure that your display connector has
    brown wires in both pins 1 and 2
    and
    red wires in both pins 3 and 5.
    if you have only one red and one brown, then you will need to link pin 1 to pin 2 and link pin 3 to pin 5 for the GID to work.
  1. Radio/Clock/Temperature display bulb type?
    By kentish_bloke in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 17:47
  2. Swapping clock/radio display
    By bones341 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:55
  3. Clock/Radio display
    By shuggler in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 23:27
  4. Clock display
    By s2yob in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2010, 00:42
vectra c swap clock for screen
vectra c clock removal
how to remove Holden vectra display
how to remove zafira b radio display
remove clock radio display vectra
remove cd30
corsa c centre display removal
how to remove display screen on a vectra c site:www.vectra-c.com
replace clock vectra sri
08 vectra digital clock removal
vectra radio removal
remove centre screen vectra c
how do you replace bulbs in the sreen on a vauxhall vectrs stereo
Replace stereo and mid screen vectra
vectra c remove center display
vectra screen removal
vectra c 2007 lcd removal
vectra c display removal
vectra c swop clock for screen
vectra c remove dashboard sat nav
vectra c large display
vectra c stereo bulb replacement
vauxhall vivaro cd30 clock wiring
vectra digital display after replacing radio
