Results 1 to 3 of 3
Thread: Terrible noise - is it terminal????? HELP!!!!!
    Default Terrible noise - is it terminal????? HELP!!!!!
    My Signum 2.2dti design auto has had a slight knocking noise coming over the past two days, which progressively got worse. It wasnt noticeable when ticking over, but as soon as gear selected, it sounded like a hammering noise coming from somewhere up front. No loss in power at all. no loss in fuel efficiency. No blue smoke. Just this horrible hammering metallic noise. I had noticed a few days earlier, when the gears changed there was occasionally a banging noise. I took the car to a local mechanic who said the turbo has blown (was replaced last year about 30k miles ago) and that was due to oil pressure problem. He says the noise is the Big end bearings and that i now need a new engine. The engine has done 166k miles,, and the gearbox was replaced 100k ago. I know for sure the CV boots need renewing. but has anyone got any other ideas?! He said do not drive the car, the engine may blow up!!!
    Ashington, Northumberland
    It may well be big end bearings mate from how you describe it. As your mechanic says, if it is BE bearings, best not to use it as it may get interesting
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    If your big end bearings are gone the knocking will get louder as you raise the revs,especially if the engine is under load.
    has the mechanic checked the turbo for failure or is he just guessing,if the turbo turbine has touched the body it may have broken a vane and entered the engine,if so the knocking could be the vane stuck on top of a piston and stricking the head when the piston tops
    eitherway the engine is unusable untill repaired
  1. good clean earth terminal
    By gdallas in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2011, 01:22
  2. Tacho output terminal?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2011, 17:13
  3. +'ve terminal heating up
    By Cam in forum Electrical & ICE (including SatNav)
    Last Post: 5th September 2010, 21:53
  4. Advert for Cadburys or Terminal 5?
    By AndrewTi in forum Comedy & Humour
    Last Post: 2nd April 2008, 00:03
  5. battery terminal oxidation
    By lakis123 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2007, 10:05
