Thread: Headlight Adjustment
    Full Member
    South West
    Default Headlight Adjustment
    Just a quick question folks,
    After fitting HID's they seem to be rather low. Been reading how to get them aligined etc, but one bit passes me...
    Most say, park next to a wall/garage door 9ft and 25ft seem to be the quoted distances etc, then alter so they align using the allen key.
    What puzzles me is how do you know they are aiming at the right height?
    If i have the car at 25ft from a wall, what height from the ground should the dipped beams be at? and how car apart?
    Or... do i just take it to my local garage, pay the £10 which seems to be the going rate and have them done properly!
    Aidi
    Sodding Typical on Sea
    I think you answered your own question matey as it will always bug you (if your like me?) that they are not quite spot on?????
    Full Member
    South West
    LOL. Yep, i think its the way forward! Just wanted to see if was just being dumb! Need to get the wheel alignment checked after new shocks and springs, so might as well get this done at the same time.
    Aidi
    Nah not being dumb it can be difficult to get them right but not blind oncoming cars especially with Xenon's as they are incredibly bright
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Think the overall consensus is that they are all aimed a bit low
    Have been looking into raising mine as well. As you say the light cut off is rather low
    Got the inspiration from Duncans post here:-
    http://www.vectra-c.com/forum/showthread.php?t=33655/
    But as of yet not had the opportunity to get out and get them adjusted plus also not sure which adjuster tilts the lenses up & down (think i've labeled the pic correctly)
    Looking forward to also being able to see properly at night with my HIDs
    Best of luck with it
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Full Member
    South West
    I read the post by Duncan, and gave it an attempt. But, i am now thinking that i might not have the bulbs located correctly. Whith the lights on, both dipped beams seem to be very bright just a few feet in front of the car... as if they are fogs.
    With hindsight, i should have marked on a wall the output of the original bulbs, then brought the new hids to the same level.
    I think ill check the HIDs are in the housing correctly before i continue further.
  1. Headlight Adjustment
    By Siggy08 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 19:05
  2. headlight adjustment-HELP
    By nikroc in forum Bodywork & Interior
    Last Post: 27th November 2009, 11:54
  3. Headlight adjustment..'how to'
    Last Post: 27th November 2009, 00:11
  4. Headlight adjustment
    By Bops in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2009, 21:39
  5. headlight adjustment
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2008, 15:54
how to manually adjust your headlights on a vectra c
vectra c headlight adjustment
vectra c 2004 fit headlamps
