Thread: CD70 'Reading' Satnav disc
    Engine : 1.9 CDTi
    Default CD70 'Reading' Satnav disc
    Is it normal for the CD70 to be reading the satnav disc?
    Mine reads it even when not usng the Satnav
    Full Member
    South West
    Mine does the same. Even if you dont have a route programmed into it, the GPS is active and knows where you are. Put the nav screen up next time you are out and about and it will track your current location and tell you the name/number of the road you are on.
    Rgds
    Aidi
    Engine : 1.9 CDTi
    What about when the stereo is off?
    Just sitting in the car doing other stuff it still does it.
    Full Member
    South West
    As in you have the ignition on or car running? If its turning and whirring with ignition off then i would say thats a problem
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yep the NCDC also does it.. it also loads in TM/TMC
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yep. All as above. Also if you press INFO then NAVI and choose MAP it will show you where you are and track where you are going.
    Engine : 1.9 CDTi
    Ah thats good then
  1. New satnav disc needed or not?
    By voxvectra7 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2012, 05:42
  2. How do you check the year of your satnav disc from the CD70 menu?
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2011, 06:54
  3. CDC 2006 reading Disc error
    By tshort2007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2009, 01:17
  4. cd70? satnav disc
    By kitson06 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2009, 22:57
  5. CD70 SatNav disc
    By andy13 in forum Parts for sale
    Last Post: 21st April 2008, 21:28
