Results 1 to 10 of 14
Thread: V6CDTi coolant loss - heater bypass valve?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default V6CDTi coolant loss - heater bypass valve?
    A mate of mine reckons I could have a leaky heater bypass valve as my car is mysteriously losing coolant. The same happened on his Saab 9-5 3.0TiD.
    I lost 0.3L of fluid in 200miles/3days. The engine runs fine, no suspicious smoke out of the back and has full power.
    3 days ago I had a pressure test done at my dealer and no leaks have been found during the test...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    anyone?
    Regular Member Maurice's Avatar
    Nutterden (D)
    Did you check the thin hose from the heater to the expansiontank?
    Mine was leaking there too..A small amout, but enough to get the
    low level warning.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Everything is bone dry around the hoses...
    Nutterden (D)
    Try to find a guy with a (endo)scope. You would be able to see the problem then in real time. Have that done on a VW that I owned.
    We could see the actual leak.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I could drive the car to the nearest hospital
    Still slowly losing coolant. No smoke, no pressure in the bottle, no visible leaks.
    Full Member Big Sig's Avatar
    Where is this valve located and what exactly does it do????
    Nov 2009
    bury
    hi guys, recently had coolant light on , topped up about half litre, ok for 20 miles coolant light back on. panic stations , removed sump cover also to change oil etc. no sign of any leak. only thing diff , heater on full taking wife to work that morn . nothing since , that was 4 weeks ago. been on long and short runs since. maybe just air locked.. good luck.....
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Both coolant and oil have no sign of contamination. New coolant 2 months ago. Noticed coolant loss about 8k ago/last month. Lost nearly a litre since. Went to Germany twice and ragged her quite a lot with no problems whatsoever. Surely that would've opened up a head gasket if it was bad? Losing more coolant now that I'm going easy on her...
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    This is a heater bypass valve. I've no idea what it does but I can't find anything similar on my Signum...nothing similar and WET...
  1. V6CDTi - Valve clearance values - URGENT -
    By Celes in forum Engine & Drivetrain
    Last Post: 31st January 2011, 12:29
  2. V6CDTi - Valve shim diameter
    Last Post: 15th January 2011, 22:26
  3. Slight coolant loss on my V6CDTi
    Last Post: 4th September 2010, 23:04
  4. turbo bypass valve
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 15:54
  5. Gsi coolant loss
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 15:13
saab 9-5 3.0 tid losing coolant
heater bypass valve vectra v6 cdti
