Thread: SAT-NAV what do i need to install??
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default SAT-NAV what do i need to install??
    I am looking to buy a sat nav what do i need which cables ??
    do i need arial?
    is it an easy job?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'm sure there's a How2 on this one... but start with question 1... is your car half or full canbus ? (3+3 buttons on steering wheel - 1/2 canbus... scrollers+buttons - full canbus).
    Half canbus can be done but requires more kit.
    Assuming you're full canbus, you'll want CD70 headunit, whichever screen is married to it from the donor vehicle (ideally full colour), roof loom and antenna, any missing harnessing/cabling for behind dash.
    Not a cheap project, but do-able.
    Sep 2010
    LEEDS
    thanks for the info,
    how many cables connect to the back of the sterio that go to the arial?
    why is there a roof loom?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    You dont have to swap arial.. you just could use one and place it where the dash speaker goes.. or just in front of it.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    My reply was based on fitting the original kit.
    As Kenp noted, if you wish you can always bypass the roof mounted antenna and fit an aftermarket antenna at the base of the windscreen - as long as it has a clear 'view' of the sky it would be fine.
    Sep 2010
    LEEDS
    were can i get arial from?
    Engine : 2.2 Direct
    OEM or aftermarked? OEM the dealers.. the other on ebay.
    Do you know that the oem VX sat nav doesn't do full post codes? The early ones don't take any and the CD70 only takes the first five digits.
    Just a bit of info incase you didn't know.
    Aug 2010
    Antrim
    Or you could just buy a Garmin. The screen on the dash board is not in a good place for Sat Nav use. Better with a portable unit that can be positioned where you can safely see it.
  1. new install in the vec
    By bensterzback in forum Quick Photo Album
    Last Post: 18th October 2010, 21:10
  2. What do I need for an install?
    By JamieD27 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 07:05
  3. My install!
    By smiley-sri in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2009, 22:44
  4. My little ICE install
    By bensterzback in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 20:08
  5. HID kit install.. help
    Last Post: 23rd December 2008, 00:05
