Thread: TD04L14T turbo for Z20NET (2.0 turbo)
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Arrow TD04L14T turbo for Z20NET (2.0 turbo)
    This a GM numbered Mitsubishi TD04HL14T turbo for use on a Vectra C or Signum with a Z20NET (2.0 turbo) engine.
    If you car currently runs with the Garrett turbo no problem you can upgrade to this turbo, it is bolt on, you will need to source a set of oil and water lines, they are available on ebay if you do a quick search. You will need a Stage 4 remap from Maptun and your car will then have 265bhp (an injector upgrade may be required with this but the UK Maptun agents called Neo Brothers can advise you on them and they are not expensive.
    If your engine is one that already has this model of turbo then it will be an ideal no hassle bolt on replacement. Save a fortune and not buy it from from your stealer..
    This model of turbo is not limited to GM cars and can be used on a variety of makes and models. A new one like this will cost you more elsewhere..
    This turbo has been bolted on to a Vectra C and run for 4 miles to test it and all was fine plus the boost was phenomenal.
    I am looking for £350.00 plus delivery. This turbo is advertised elsewhere.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    btw my turbo upgrade project is still going full steam ahead, i just have too many turbos now and this is surplus. I will be selling the Garrett turbo in a couple of weeks as well.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    bumpity bump...
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    This is no longer available..
    Please close thread.. thanks
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. z20net 2.0t no turbo
    By mccluskey119 in forum Engine & Drivetrain
    Last Post: 14th August 2012, 14:53
