Thread: Help Rear caliper gromet removal
    Plymouth
    confused Help Rear caliper gromet removal
    hello
    While checking a noise with the rear brakes i decided to change the discs and pads simple.
    Well, i have noticed that the rear caliper is seized and needs changing, i have everything removed apart from the handbrake gromet which i cant seem to get off. Haynes seems to think you just pull it off but this hasn't worked.
    Anyone who has any advice would be really appreciated.
    many thanks
    Jun 2007
    Scotland
    it is a very tight fit but it does pull out from the caliper. I used a pipe wrench to grip the grommet.
    Jun 2009
    Middlesbrough
    Hi
    I have just done the same thing, ****** haynes manuals!
    It is a very tight fit indeed, I used WD40 and a pair stilsons.
    I also used a large screwdriver and hammer to try to push the grommets out from the opposite side, this also worked on one side of the car.
    Paul
    Sodding Typical on Sea
    Anyone have any pics of this wee beastie??? I am nosey (and am needing to do mine too)
  1. rear caliper
    By roverjay in forum Engine & Drivetrain
    Last Post: 5th January 2013, 17:20
  2. wiring gromet
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 14:57
  3. caliper paint removal...
    By shb1988 in forum Styling
    Last Post: 9th March 2011, 22:55
