Thread: HID Ballast Location
    Full Member
    South West
    Default HID Ballast Location
    Howdie,
    I have just fitted the HID kit on my Vec C Facelift. Looking at the front of the car, the ballast on the right fitted nicely into the large are under the battery box lid.
    However, i am struggling to find somewhere to mount the one on the left.
    Where have you fitted yours?
    Any info would be appreciated please chaps.
    Rgds
    Aidi
    Sodding Typical on Sea
    I fitted mine onto the ecu under the airbox in the inner wing area. I struggled to see a neat location topside and as the inner wing has that large ECU I thought a great place for the ballast and canceller to go.
    Hope this helps
    Derek
    Dunstable
    If you take the headlights out, there is a space built into the underside of the headlight that the ballast fits into perfectly. Can be stuck there and you won't see it
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    I used the double sided pad with my kit and stuck it onto the left hand side of the airbox, and the bonnet closes fine with it there too
    Full Member
    South West
    Thanks chaps, Ill have a look at these places. I am not the most mechanical minded person, so removing bits from the car is not something i would normally do!
    Does the front bumper need to come off to remove the headlight?
    Quote Originally Posted by Ademusic View Post
    I looked at that but didn't think I had the room, thats a good position indeed
    Dunstable
    Yeah, bumper needs to come off to remove headlights. I have the normal size ballasts, not the slim ones, and there's plenty of room in the space under the headlight for them. They're out the way there and is the best place for them.
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I did exactly the same as in this thread:-
    http://www.vectra-c.com/forum/showthread.php?p=1060742
    Hope it helps
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Full Member
    South West
    Thanks again, I like the idea of installing under the light cluster. Just need to get the courage to get the spanners out and take the bumper off!
    Rgds
    Aidi
    Full Member spennny's Avatar
    Blantyre
    I dont mind helping mate if your near me ?
  1. HID ballast
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 13:57
  2. Location of HiD Ballast
    By Ginge7289 in forum Styling
    Last Post: 6th February 2011, 00:24
  3. BTCC. Ballast!?
    By Vectra_C_Chris in forum Motorsport / Formula 1 etc. chat
    Last Post: 8th November 2010, 18:16
  4. Hid's Fitted Today... Ballast Location / Pre Face
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2010, 22:48
vectra c hid ballast locations
