Thread: Ignition barrel replacement video ?
    Regular Member bighammerfan's Avatar
    hillingdon
    Default Ignition barrel replacement video ?
    Im trying to find a video showing how to change the barrel on my 2001 vectra......anyone know of any ?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    If its just the actual barrell, then im sure you insert the key and turn to position 2 (try the other too just in case), then there should be a tiny little hole somewhere within the acuminium casting, you need to push that in with a nail/strong pin or similar, then it should pop out with the key.
    To replace is simply turn to same position and push in and turn key then pull out.
    Used to be like this on the old Cavalier, and I did it once of the pre-face Vec-B, should be same me thinks!
    Mileage : 000
    If it is a Vectra B then there is a very small hole underneath I think it is situated. Put a small screwdriver in and push whilst pulling the barrel out with the ignition key (in auxilary position).
    hillingdon
    job done now but new key needs coding
  1. New ignition Barrel??
    By leeoliver2011 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2012, 09:02
  2. Ignition Barrel
    By Eskimo in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 12:42
  3. Ignition replacement advice please
    By bighammerfan in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2010, 11:07
  4. boot barrel
    By bozzv6 in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2010, 10:07
  5. Ignition Switch replacement
    By magpie27 in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2009, 17:13
