Results 1 to 10 of 18
Thread: CV joint
    ayrshire
    Default CV joint
    hi all, im getting a clicking noise when driving , i only notice it when windows down , noise is when car is driving straight or going round corners , is this likely to be a cv joint ? i have checked for stones etc in tyre and to temporarily cure the problem i drive with windows up and stereo on ...thoughts on possible cause please..thanks
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    doubtful its a cv as you would usually notice on full lock or taking up drive and it would be a knock rather than a light clicking noise.
    i would double check the tyres and also check nothing is fouling the brakes
    ayrshire
    hi again folks ..still have this problem , car has passed mot since this problem has started ,obviously (i hope ) it isnt anything serious but its annoying me ...it is exactly the same , clicks when what feels like the wheel makes a full turn , it does it driving straight or round corners ...its defintley something to do with wheels as noise goes away when you stop and car idles fine...any ideas , i have checked tyres , the car has no vibration through steering at any speed ..not essential i think but is seriously doing my nut in ..i mean we get about five days of sun in scotland and when i drive round in car with windows down i have to put up with the click click click lol let me know ur thoughts...ty...
    Engine : 1.9 CDTi
    Jack it up and spin the wheel
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by lee gsi View Post
    Get The Wheels Up In The Air And Spin Em...Then Wheel Off When You Suss Where Its Coming From..Even Check In Between Pads/Discs..Case You Have Picked Up Some Crap
    ayrshire
    thanks for the thoughts i did this , its the drivers side rear ,i took wheel off removed rust round disc and backing plate ,put wheel back on and it is the same , my rear discs have about half inch of rust on the disc from top down disc face ...ive tried to clean and when i spin it their is no sound but when i put wheel back on and drive it the noise comes back...maybe new discs and pads....
    Engine : 1.9 CDTi
    Sounds like the calliper has stuck.
    ayrshire
    cheers lee , im not sure but you might tell me different but i spun the wheel with handbrake off while jacked up and no noise i then removed wheel and when i put it back on i had h/b on and it was solid so what im trying to say is i think its operating ok, i know its my back wheel cause i drove slowly and had my son run along side and it is clearly that wheel ..thanks again bud
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check abs exciter ring.
    ayrshire
    hi , i took car to garage who told me my rear discs and pads were stuffed and needed replaced and i might aswell replace the shoes aswell while im at it...? i didnt think my 05 vec c had shoes ...anyone confirm please...
  1. cv joint
    By beat275 in forum Engine & Drivetrain
    Last Post: 1st February 2013, 15:27
  2. cv joint gone??
    By justin32 in forum Suspension, Wheels & Brakes
    Last Post: 7th January 2013, 20:00
  3. CV joint gone
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2012, 20:14
  4. C.V. Joint?
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 21:25
  5. cv joint
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2011, 17:08
