Results 1 to 10 of 13
Thread: swirl valves
    Aug 2010
    south northamptonshire
    Default swirl valves
    i checked mine today and relised that there was a tiny piece of oil around one of them is there anything to worry about as i know there are some problems with them. btw its a veccy c 1.9cdti 150bhp. cheers
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by bridge_eee View Post
    There should be no liquid oil. However as they wear turbo pressure + egr gasses escape around the spindles and oily sooty black deposits form around them. It is this sooty deposit that eventually jams the swirl flaps - later type manifolds are modified to try to stop this jamming.
    In really bad cases the underside of the engine cover (Vauxhall call it the 'beauty' cover) can be covered in soot.
    As there are no seals for the swirl flap spindles, as they wear (plastic rotating in an aluminium hole) some leakage is normal.
    IMHO a 'tiny piece' of black soot is normal after a fair few miles and nothing to worry about.
    Aug 2010
    ok lovely cheers its clean all over apart from that tiny little bit of oily substance. il keep an eye on them cheers for putting my mind at ease.
    Portugal
    Anybody as removed the swirl flaps? If yes, there is a significant difference?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by pedroamg View Post
    It would increase smoke levels low down but probably increase response. Their purpose is to make sure combustion is complete ie all available oxygen is burned eliminating excess soot and NOx emissions.
    Personally I think when the manifolds were updated - it was an opportunity for Vauxhall to remove them but they didn't.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Aug 2010
    Stoke on Trent
    Quote Originally Posted by mozzer99 View Post
    This is just what one of my swirl valves looks like.. the other three aren't as bad (but have lifted)... the top of my inlet manifold is really filthy and the underside of my engine cover is starting to take a hit... it goes in tomorrow for a new inlet manifold.. ..
    I also had a look at my EGR yesterday and although sooty is wasn't blocked at all nor anywhere near as bad as I feared... however a quick look inside the manifold where the EGR bolts onto was completely solidly blocked with a black sooty deposit... so effectively my EGR was completely blocked off...
    Portugal
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    I had made some modifications to my manifold and the flaps are working, but there is a bit of dirt at the top of the inlet manifold, and i'm afraid these flaps could break after a couple of years. Because of that i'm thinking to remove the flaps and seal the holes. it's more cheap, and clean
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    I had the manifold replaced and I've got dirt there too.
    Gazza4
    preston
    by blocking the swirls out then in essence you'll have a cdti 120
    is that what you want??
    Portugal
    Quote Originally Posted by mparks8590 View Post
    i'm thinking to remove the flaps, and seal the top of the manifold. the holes to the engine stay open forever. it's like having the flaps always at the open position.
  1. Swirl valves on an '08
    By stevoxsi in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 22:11
  2. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  3. re swirl valves
    By steve alan in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 08:52
  4. Swirl valves
    By MattHD in forum Engine & Drivetrain
    Last Post: 18th April 2011, 12:45
  5. swirl valves
    By scoobyman in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2008, 21:14
vectra c black soot near valve
