Thread: estate fuel return pipe
    Jun 2006
    Kirkintilloch, Scotland
    Default estate fuel return pipe
    Car is a 2004 2.2 direct petrol estate.
    The fuel return pipe has a nasty kink in it and I have obtained a replacement.
    Does anyone please know how I gain access to the petrol tank end? Is there perhaps a plate inside the car to gain access?
    Thanks,
    Dave
    Jun 2006
    bump
    Jun 2006
    bump
    north east
    plate under the rear seat normaly.
    Jun 2006
    Quote Originally Posted by roswell View Post
    Before I struggle to remove the rear seat anyone able to confirm whether or not it is actually under the seat or otherwise?
    Thanks,
    Dave
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Underneath the rear bench, remove it you'll see one massive round hole, underneath the rubber cap you'll see it
    Jun 2006
    Quote Originally Posted by plasma View Post
    Many thanks Plasma. Sounds like you've been there.
    Do you know if I will be able to replace the both pipes between the tank and the fuel filter without removing anything else? (Its a 2004 estate)
    Regards,
    Dave
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    cant really tell you any further, not got any experience of doing that, sorry
  1. cdti fuel feed pipe
    By ronnie63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2012, 14:50
  2. 1.9 CDTI Fuel non return valve help
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 9th April 2012, 08:09
  3. Oil leak from oil return pipe after fitting turbo
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 15:00
  4. PLEASE Fitting fuel pipe help
    By vwsaxon in forum Vectra C / Signum Troubleshooting
    Last Post: 28th May 2011, 19:37
