Thread: Replacing front subframe bushes
    Regular Member Cossy's Avatar
    East Yorkshire
    Default Replacing front subframe bushes
    Well ive noticed a knocking from the front end, its had new front arms and drop links so that wasnt the issue.... But i noticed there is 10-20mm of play in the front subframe bushes on the drivers side!
    Found a full set on ebay for £60, now the big question is how easy are they to replace? Ive got a machanic friend who helps me do most things, just wondered if anyone had done it before, how easy was it and how long did it take??
    Thanks in advance
    Steve
    Sodding Typical on Sea
    Very easy in truth, there is a good How-2 on it in that section IIRC a 10mm spanner with the wheels off
    East Yorkshire
    Really? I thought it would be a pig of a job. Ive had a look through the how2's and cant seem to find anything on changing the front subframe bushes? Could you point me in the right direction please?
    Thanks for your response
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Derek Mc View Post
    Those are anti roll bar bushes
    With regards to the subframe bushes, your right is can be a bit of a pig to do, ideally you'll need an engine hoist to support the weight of the engine while you undo the subframe. You'll also need to make up an alignment tool (see haynes manual) as the subframe needs re-alligned hth
    East Yorkshire
    ahh i thought it shounded too good to be true with a how2 on what to do. I thought it might be abit of a pig to do, not sure if i can do it on my driveway as i dont have a lift :s
    alignment tool, oh that sounds abit complicated, im thinking its going to be an expensive job for a garage to do aswell?
    Sorry sorry mate,
    The subframe is easy at one end a nightmare at the other.
    Two bolts hold the strut on, two Torx22's hold the rear end of the wishbone in situ and a nut bolt IIRC 20mm on the front allows you to slide the bone out.
    Support the hub assy.
    The front part of the subframe bushes need a bench press to get a new bush into
    The rear is a complete new bush at around £80, the front is about £5
    I had the movement you describe in my Saab bushes, spent a fortune and changed them but still had the same exact noise!
    To change the front bush needs a bench press of about 10to
    East Yorkshire
    Thanks for the info but i think you are talking about the bottom arm bushes, the bushes which im having the issue with are the ones which mount the frame that holds the engine into the car, to the body of the car. One behind the steering rack at each side and two at the front, at each side of the bottom radiator mounts. Any ideas about these?
    Jul 2010
    Southampton
    Hello Cossy. Do you have any progress? I have to change my bushes, and I am curious about yours
  1. N/S Front Subframe mount
    By cookie in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2013, 10:47
  2. Front subframe mounting bolt
    By Batters in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2012, 21:20
  3. Torque settings for Subframe Bushes
    By JDL in forum Engine & Drivetrain
    Last Post: 6th October 2011, 21:32
  4. Front ARB bushes...
    Last Post: 21st August 2011, 17:44
  5. facelift front subframe help!
    By andrew382 in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2009, 17:59
replace front subframe vauxhall vectra
vectra c front d bushes
vectra c front subframe replacement
zafira b cant undo subframe bolt
vectra b front subframe bushes
corsa c front subframe removal
vectra c change front sub frame
front rear subframe mount vectra c
vectra c front subframe removal how hard
vectra c anti roll bar bushes fitting
replacing bushes in front subframe
vectra subframe tool
vauxhall zafira front subframe bushes
how long does it take to change a sub frame on a Vauxhall zafiera
pressing out vectra c hub bush site:www.vectra-c.com
vectra c subframe bushes
vectra c front bushes
vectra c front subframe bushes replacement
vectra c front suspension bushes
vectra d front subframe removal tool
anti roll bar bush replacement vectra c
how to change subframe bushes vectra 2007
how to check vauxhall vivaro subframe bushes
vectra c subframe
vectra c rear d bushes
