Thread: Dash switch illumination
    Regular Member family guy's Avatar
    Jul 2009
    salisbury
    Default Dash switch illumination
    Does anyone know wether its possible 2 wire in an led or similar 2 light up the sport switch? Its only there 4 cosmetic reasons but id like it 2 light up with the rest of them. Thanks
    Blantyre
    Quote Originally Posted by family guy View Post
    Was really easy...just took the vents out and could reach everything I needed to connect them up. I thought it'd be the live that wasn't present, but it's the common or earth that just needs connecting (Brown wire I think) from each switch. Just bared the common wire on the hs switches and the same for the tc switch or alarm switch would do, and connect them up. 1 wire, and it illuminates them and also turns the little light on when you turn the scroller wheel...dead easy, so don't see why yours shouldn't be the same
    Post 9
    http://www.vectra-c.com/forum/showth...ht=sport+light
    Regular Member eaglepva's Avatar
    Up North
    How do you take the vents out mate?
    Blantyre
    Remove the silver strip underneath them by pulling from the left with the door open, and it reveals the screws
    Up North
    Thanks m8 going to try and get my tc and sports button to light up today.
    Jul 2009
    salisbury
    My car actually has heated seats so they light up cos the system is complete. Im nt sure i can make the sport button light cos there is no plug behind it, however there is a plug behind the blank (but not 4 long) 4 tc so how will i b able 2 light it up with no plug? There will b no led in it?
    Liverpool
    I thought all switches would simply push in and illuminate??
    Dunstable
    Mine hasn't got the plug for the sport switch either. I haven't bothered wiring it up to illuminate, seems too much work just to get the light to come on As most of the cantre console would have to come out to get to it
  1. Dash illumination? Volts & fuses?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 22:51
  2. interior light switch illumination?
    By Mikecdti in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 22:19
  3. Best head-unit illumination colour match to std Dash...
    By Dan_BlackSRi in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2009, 10:53
  4. Dash Illumination change.
    By Merick in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 10:01
  5. dash switch?
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2007, 01:12
heated seats dead including switches vectra c
