Thread: Whats The Best Auto Gearbox Oil
    Regular Member s-owen4's Avatar
    Aug 2010
    Consett
    Default Whats The Best Auto Gearbox Oil
    Whats the concensous of opinion as to the best auto gearbox oil to use, I am going to tackle the change my self as it looks quite a simle job, local dealer wants £90 to do the job . I have read quite a bit about addatives for gearbox oil such as Lubegard, any one recomend these or not????
    West Yorkshire
    If you have the AF40-6 box then YOU MUST ONLY USE AW1 FLUID.
    Nothing else will do. I would be extremely wary of any additives etc.
    If it is the AF40-6 then £90 really isn't that bad considering it needs 8 litres of fluid (about £6 a litre at trade) and draining the old fluid out is not straightforward - you'll only get about 3 litres out if you just drop the sump plug!!
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I had my car servived this week at MPG and was informed that I needed a auto box oil change, 4 years and 42000 miles plus remap and towing a caravan. Ian said that Tech 2 is needed to change the oil as it tells you how much oil is in the box as there are no level guages etc.So if that is the case maybe get a garage to do it and I was quoted £45 for it to be done but he didnt have the oil in stock so will get it done when he calls to say he has stock
    West Yorkshire
    £45 is a brilliant price.
    Andy, make absolutely sure he is using AW1 fluid. Don't feel like you're being awkward by asking the question, as it is you who will have to live with a broken gearbox if they get it wrong. GM state quite clearly that common trans fluids such as Dextron etc. are not to be used.
    Aug 2010
    Consett
    Sorry to appear thick, but not sure what box it is, the engine is 1.9cdti (150) the box is 6 speed, can anyone advise???
    May 2007
    WINSFORD
    I will ask him when I book it in but I think he would know as MPG is a VX specialist and does EDS Remaps etc and has the most powerfull Vectra VXR around.
    My gearbox is the same as yours as far as I know as its a 56 plate Facelift 1.9cdti 150 6 speed but a Vectra
    Huddersfield
    My local dealer wanted circa £140 for changing the fluid.
  1. Auto gearbox.
    By VeccycJay in forum Engine & Drivetrain
    Last Post: 15th May 2012, 18:56
  2. auto gearbox
    By Paddy in forum Engine & Drivetrain
    Last Post: 26th March 2011, 22:40
  3. F23 auto gearbox oil
    Last Post: 12th March 2011, 21:56
  4. Auto gearbox.
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 14:25
  5. auto gearbox?
    By no1golfer in forum Engine & Drivetrain
    Last Post: 24th July 2009, 22:09
