Thread: Vectra mad or Mad Vectra?
    Sep 2010
    Southampton
    confused Vectra mad or Mad Vectra?
    Hi folks, just joined this site as found it whilst looking for help on fixing driver side headlight. Well actually to fix the indicator light housing which mysteriously 'popped' out of it's housing. Nobody seems to have heard of this before, and since lights all working, wondered how to access the headlight assembly to 'pop' the light back into position.
    Any ideas (apart from buying a new headlight!).
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Weird one, but can you not buy one off of ebay?
    Gazza4
    Sep 2010
    Southampton
    Default weird headlight
    Hi Gazza
    Did look on eBAY however, have requested that the light be replaced/sorted under the warranty. As car has done 25000 miles but only 2 years old the warranty only covers headlights up to 18500 miles. However, Vauxhall have never heard of this happening before. So fingers crossed and after sending photos of said problem, they may decide to replace it. Funny thng is the dealer actually suggested that it could have been due to impact damage. However, as there is no damage to bodywork anywhere on the car it is a mystery. will post response if they replace it.
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    hi and welcome to Vec-c ...you got any pics to post here of the problem ???
    guessing you have a facelift....the head light are easier to access if you take the airbox out ...you can do the airbox mod while your at it .....it just entails removing the top of the trumpet cone underneath the air filter ...this just enables the car to breath a little easier ..HTH
    Sep 2010
    Southampton
    Default Headlight problem (indicator light out of socket)
    Thanks for your advice . I hope I have attached a few photos of the problem. Don't know if they are clear enough to show what has happened. The whole housing for the indicator bulb has come out. Looks like there may have been an initial problem with the headlight when it was first installed.
    Thanks again
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
