Thread: Please help?? 1.9 cdti 150 limp mode p1125
    Sep 2010
    milton keynes
    Default Please help?? 1.9 cdti 150 limp mode p1125
    Hi all could anyone help me?? I have a 2004 vectra sri 1.9 cdti 150. I haven't had it for very long, all was fine the car drove beautifulyup until I was on the motorway stusk in traffic. When the traffic cleared the car went into limp mode as I tried to accelerate back up to speed. I pulled into nearest service station, the spanner light and engine management light came on. After a few minutes the car was running fine but the lights stayed on. The green Flag guy plugged it in and came up with code p1125 and said it was the apps. Whatever that is? I'm no mechanic!!! He cleared the code and all was fine for 160 miles when it happened again. I've had it plugged in by a local garage and the code still came back the same. I understand that there are 5 sub codes but every time I take it to the garage there are no codes. Apart from this problem it runs absolutely fine I've cleaned the EGR but it still does it.
    Sorry for the long post I'm just at the end of my tether and can't afford huge garage bills!
    "P1125 Throttle position sensor intermittent" I believe.
    Also read this thread http://www.vectra-c.com/forum/showthread.php?t=53927
    Someone has had the same problem as you
    Sep 2010
    milton keynes
    Thanks big sig, does that sound like a new throttle body do you think? Any idea how much these cost?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Another one... Get the electrics checked between the pedal and ECU m8. I had the pedal changed and mine still does it.
    Gazza4
    Sep 2010
    milton keynes
    Also the temperature gauge seems to work intermittently too, sometimes its fine sometimes it doesn't work!
  1. 3.0 V6 CDTi occasional limp mode...
    By fandango in forum Engine & Drivetrain
    Last Post: 21st June 2016, 13:24
  2. Cdti limp mode???.
    By steve1312 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2012, 00:46
  3. 3500 rpm then limp mode 1.9 cdti
    By lesron in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:04
  4. Limp mode under acceleration - 3.0 CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 23rd December 2009, 01:41
  5. 1.9 cdti 150 limp mode
    By jeets in forum Introduce yourself.
    Last Post: 30th May 2009, 20:29
vectra z19dt p1125 www.vectra-c.com
