Results 1 to 10 of 15
Thread: URGENT help required. Put petrol in Deisel engine
    Staffordshire
    Default URGENT help required. Put petrol in Deisel engine
    Any one advice me on what to do....I just put 3 litres of petrol in an almost empty diesel engine and wondered if I can fill the tank up to the top with diesel and 'get away' with causing no damage? Any one ever done this?
    The car is at the moment blocking the forecourt of my local garage so quick responses would be very gratefully received !
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Fill it with diesel and hope for best...
    Back in the day i think they used to add a couple of litres of petrol to thin the diesel....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Wouldnt risk it, phone a recovery service to remove the petrol from the tank.
    Gazza4
    May 2008
    Derbyshire (south)
    Brim the tank with derv it'll be fine, its been know before to add a bit of petrol into diesel, it burns hotter..
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    As long as you havent started it push it back to the pump and brim it right up with diesel before starting it,
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Just found this so ignore above... as in my comment lol
    Depends on what type of engine you have fitted.
    If it is a a'common rail' diesel then do Not run the engine as even a small amount of petrol will destroy the high pressure electronic injectors.
    If it is one of the older type diesels, neat petrol will destroy the fuel pump seals and damage the injectors, BUT as you have a mixture that is mostly diesel, the wax lubricants are still in the system which will protect both pump and injectors.
    Only you know how much petrol you have put in, if you are confident of the percentages quoted then you can still run the engine without any problems, just dont make it work too hard.
    Worst scenario is drain what you can from the fuel tank and refill with fresh diesel, and bleed the fuel up to the pump - there is no need to flush the system unless a common rail system is used.
    4 years ago
    Although other sites have said if its less then 10% petrol it should be ok?!?!?!
    My mum did it in her Golf PD diesel. Brim it up and keep it topped up for a few weeks. I wouldif it was mine.
    Staffordshire
    Cheers everyone, just been on the AA website and they state :-
    If you've added less than 10% petrol (5 litres in a 50 litre tank) – Top up with diesel and run normally unless the manufacturer has advised otherwise
    SO.......should I trust that advice?
    May 2008
    Derbyshire (south)
    As above fill the tank & keep it topped up too for a few fills after... you're well within that spec above..
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    my dad tried running my old vec b dti on pure petrol it didnt like it a lot lol!.... Drained the fuel filter filled it with diesel, filled the diesel tank with 25litres and all ok, except where the tank was rusty and the derv was keeping it sealed the petrol cleaned it out and made it leak lol..... the mix was roughly 5litres derv left in tank and 5litres petrol... so a 50% mix
  1. Urgent help required please
    By Tombird in forum Engine & Drivetrain
    Last Post: 16th December 2012, 15:37
  2. Urgent help required.
    By floppus in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 11:50
  3. 2.2 petrol or 2.2 deisel??
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 23:50
  4. Urgent help required..
    By siz1 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2008, 20:22
  5. Petrol in deisel 2.2dti now won't run - help!!
    By Paul from Derby in forum Engine & Drivetrain
    Last Post: 19th July 2008, 11:00
put petrol in z19dth
