Results 1 to 2 of 2
Thread: ABS light
    Regular Member VectraGezza2010's Avatar
    Jan 2010
    Anstruther
    Default ABS light
    Helloo Everyone hope someone on here can point me in the right direction or give some info on this problem.
    All my ABS hub wheel sensors have been replaced and the Vauxhall garage at fareham have said that its a brake in the wiring harness.
    Has anyone had this problem before on the vectra 1.9 CDTI SRI 150 Before ? A
    If so where do u think would be the cheapest place around the hamshire area to get it fixed.
    Got Quoted £850 if the fault was a small wiring problem and £1500 if the harness travels around the car does this sound a fare price ???
    Any info would be much appreciated
    Jul 2009
    The Rift, Cardiff
    Thats alot of money!
    Have a look at the corrosion I found in one of my connectors that was causing the abs light to stay on
    http://www.vectra-c.com/forum/showthread.php?p=1201021
    Might save your hard earned.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
