Thread: Difference of 2.8 T engines
    Sigtuna Sweden
    Default Difference of 2.8 T engines
    Hi all..
    What is the difference between 2.8T: 230, 255, 280 and 325 hp.
    Is it something other than software??
    Is it another turbo??
    Regular Member PORKBALLS29's Avatar
    Epping
    the differences are map, exhaust, airbox, cam profile and on the 325 i think it is bigger turbo.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Yep the Insignia one has a different turbo. Other than that they are all the same apart from the later 280 vxrs which apparently have different cams. (Although with it being vvt - variable valve timing I cant see how this makes a difference).
    Its basically just a remap... and the extra kit with the Vxr like the exhaust. The airbox on the vxr just has a hole added for extra intake volume but on testing it was said to add 10bhp! Must of been one hell of a restriction
    Its an absolutely cracking engine. Baring in mind many engines are modified from the 80's and 90's (aka all of the Mitsu Evolution up until the latest model have the same engines), this 'fresh millenium' build should be reliable over heavy mileage
    West Yorkshire
    The EPC only lists two sets of cams for the 2.8's - one set for autos and one for manuals.
    Regular Member Jezzy's Avatar
    S.E
    The Insignia's version of the 2.8 has variable valve timing on both camshafts - I don't think the Vectra's has that.
    West Yorkshire
    Yes it does
    It's the same engine (GM HFV6 LP9 turbo) with a different turbo.
    S.E
    Quote Originally Posted by stampede View Post
    Yes it does
    No, TIS clearly states that on the Vectra's 2.8 only the intake valves have variable timing.
    Sigtuna Sweden
    This is not the answer to my question, but anyway little info about the v6....
    2.8L V-6 Turbo (LP9)
    2006 Model Year Summary
    All-new variant and application for global V-6 family
    • Twin-impeller turbocharger
    • Unique double-wall exhaust manifolds
    • Engine-mounted oil cooler
    • Robust 356T-6 aluminum cylinder heads
    • Air-to-air intercooler
    Full Descriptions of New or Changed Features
    ALL-NEW VARIANT AND APPLICATION FOR GLOBAL V-6 FAMILY
    As the third variant of GM’s sophisticated global V-6 engine family, the 2.8L V-6 Turbo debuts in the Aero models of the all-new 2006 Saab 9-3 SportCombi, Sport Sedan and Convertible. It features a high-efficiency twin-impeller turbocharger and features high specific output as well as a broad torque band to deliver the performance of a larger-displacement engine.
    TWIN-IMPELLER TURBOCHARGER
    The turbocharger housing uses two impellers fed by a unique dual inlet chamber from the exhaust manifolds on each cylinder bank. A single compressor feeds pressurized air into the fixed volume intake manifold. This design takes the most advantage of the exhaust pulse energy for quick throttle response and smooth power increase.
    UNIQUE DOUBLE-WALL EXHAUST MANIFOLDS
    Special exhaust manifolds made of two steel pipes, one inside the other, lead to the double-duct turbocharger housing. There is an air gap between the inner and outer pipes, to insulate heat and noise.
    ENGINE-MOUNTED OIL COOLER
    An engine-mounted oil cooler is attached to the left side of the engine block to promote the longevity of the oil.
    ROBUST 356T-6 ALUMINUM CYLINDER HEADS
    The cylinder heads are constructed of stronger 356T-6 aluminum to ensure durability with the additional heat generated by the forced induction of the turbocharger.
    AIR-TO-AIR INTERCOOLER
    To lower the temperature and increase the density of the intake air, an air-to-air intercooler is incorporated into the intake air system.
    Overview
    The 2.8L V-6 Turbo was introduced for the 2006 model year simultaneously in North America for the Saab 9-3 and in Europe for the Saab 9-3 and Opel Vectra. The 3.6L V-6 VVT was the first engine in GM's sophisticated, global V-6 engine family and debuted in 2004. A naturally aspirated 2.8L was added for 2005. The global V-6 architecture was jointly developed by GM technical centers in Australia, Germany, North America and Sweden. The engine's design is based on the philosophy that a true family of global engines provides the best value and performance for the customer and the best return on investment for General Motors. The engines apply the most advanced automotive engine technology available, from state-of-the-art casting processes to full four-cam phasing to ultra-fast data processing and torque-based engine management. Each
    delivers a market-leading balance of good specific output, high torque over a broad rpm band, good fuel economy, low emissions and first-rate noise, vibration and harshness control, with exclusive durability enhancing features and very low maintenance.
    The turbocharged 2.8L has a slightly reduced compression ratio of 9.5:1 versus 10.0:1. The sand-mold-cast block features strong cast-in iron bore liners, six-bolt main caps, and inter-bay breather vents.
    Like the earlier Global V-6 engines, double overhead cams, four-valves-per-cylinder heads with silent chain valvetrain continue to contribute to the V-6 Turbo’s smoothness and high output. The silent chain drive operates with less noise due to an inverted tooth design that spreads out the period of engagement between the sprocket and chain. By lengthening the period of contact between the sprocket and chain, the force of the initial impact between the two is reduced because it is spread out over a longer time period. Therefore, the noise created by the initial sprocket/chain impact is significantly reduced. The result is much quieter and smoother sprocket-to-chain engagement, and that makes for a smoother and quieter engine.
    The 2.8L V-6 Turbo employs cam phasing for variable valve timing to change the timing of intake valve operation as operating conditions such as rpm and engine load vary. The result is linear delivery of torque, with near-peak levels over a broad rpm range, and high specific output (maximum horsepower per liter of displacement) without sacrificing overall engine response and drivability.
    The V-6 Turbo uses electro-hydraulic vane-type phasers to rotate the intake camshafts relative to the cam-drive sprockets. The variable valve timing system was developed for maximum durability and outstanding noise, vibration and harshness control. It is virtually impervious to particles or contaminants in the engine oil and minimizes the chance that the phasers can stick, even in the most demanding operating conditions. The phasers adjust cam timing quickly and seamlessly for optimum performance, driveability and fuel economy.
    Aluminum-intensive construction extends to the V-6 Turbo’s pistons, which are cast aluminum and feature full floating wristpins. Finally, the global V-6 engine family was developed with pressure-actuated oil squirters in all applications. Three jet assemblies in the block each hold a pair of oil-squirting jets that drench the underside of each piston and the surrounding cylinder wall with an extra layer of cooling, friction-reducing oil. The jets are activated when oil pressure reaches a prescribed level. They reduce piston temperature, which in turn allows the engine to produce more power without reducing long-term durability. Moreover, the extra layer of oil on the cylinder walls and piston skirts further dampens noise emanating from the pistons, meaning quieter operation.
    The V-6 Turbo’s durability enhancing features included a polymer coating applied to the piston skirts. This high-tech coating was developed to withstand the heat and friction generated by piston movement in the cylinder, and it allows tighter piston-to-bore clearances without bore scuffing. The polymer coating extends the benefits of the floating-pin piston and rod assembly and further reduces noise generated by the piston’s movement within the cylinder. The coating also helps limit bore scuffing, or abrasion of the cylinder wall over time from the piston’s up-down motion. The net result is a quieter, more durable engine.
    The strength of a forged steel crankshaft ensures the durability required of high output variants of the global V-6 engine family, and it adds an extra level of robustness in the 2.8L Turbo engine. The V-6 Turbo’s connecting rods are manufactured of sinter-forged steel. Sinter-forging is considerably more expensive than conventional casting or wrought forging. Yet because parts are manufactured with much greater precision, they require less machining, and both machine tooling costs and manufacturing time are reduced. Overall assembly efficiency – and quality – increases.
    The 2.8L V-6 Turbo’s sequential fuel injection manages fuel pressure at the injectors and eliminates a fuel return line from the engine to the fuel tank. This "returnless’’ injection – also known as a demand system – improves performance and greatly reduces emissions. It is one of
    the most efficient fuel-delivery systems in production and, true to the V-6 VVT global development philosophy, provides the foundation for several fuel-injection variants that can be tailored to market demands or legislative mandates without extensive re-engineering. The vehicle fuel tank has a variable pressure supply pump which regulates fuel pressure between 3 to 5.5 bar which improves the dynamic range of the fuel system this fuel pressure is regulated by a fuel pressure sensor on the fuel rail
    All of the global V-6’s fuel delivery components, from the fuel pump to the delivery line to the injectors, have been developed to minimize operational noise. The fuel rail is fitted with an internal fuel pressure damper, which virtually eliminates harsh pressure pulses.
    Electronic "drive-by-wire" throttle eliminates a mechanical link between the accelerator pedal and throttle plate. The global V-6 has no throttle cable; instead, a potentiometer at the pedal measures pedal angle and sends a signal to the ECM; the ECM then directs an electric motor to open the throttle at the appropriate rate and angle. Electronic Throttle Control (ETC) is integrated with the ECM, which uses data from multiple sources, including the transmission’s shift patterns and traction at the drive wheels, in determining how far to open the throttle. With this data, the V-6 effectively anticipates the driver’s demands, whether it’s a slow-speed parking maneuver or wide-open throttle operation on the open road, and responds appropriately. ETC delivers outstanding throttle response and greater reliability than a mechanical connection. Cruise control electronics are integrated in the throttle, reducing the amount of wiring required, further improving reliability and simplifying engine assembly.
    The global V-6’s coil-on-plug ignition delivers the highest energy spark and most precise timing available. The increased efficiency of coil-on-plug spark contributes to lower emissions. The system has no high-tension spark plug wires and fewer parts than conventional ignitions, improving durability, allowing more efficient engine assembly and enhancing build quality.
    Spark timing is managed with both a cam sensor that reads a reluctor wheel on the cam phaser and a sensor that reads a reluctor wheel pressed onto the crankshaft. This dual-measurement system ensures extremely accurate timing for the life of the engine. Moreover, it provides an effective back-up system in the event of a sensor failure.
    On the global V-6, a single ME9 microprocessor manages the following functions and more: Cam phasing for variable valve timing, which improves performance and efficiency; electronic throttle control, with different throttle progressions based on operating conditions and driver demand; torque management for traction control and all-wheel drive; the returnless fuel injection system with injection and spark-timing adjustments for various grades of fuel; the ignition system and knock sensors, which push spark advance to the limit of detonation (hard engine knocking) without crossing over, maximizing fuel economy; fast-heating oxygen sensors with pulse-width modulation, which varies electrical current like a rheostat rather than an on-off switch and allows lower cold-start emissions; and the variable intake manifold. The ECM provides a limp-home mode for ignition timing, in the event either the crank or cam sensor fails. It will continue to control timing based on data from the functioning sensor, and advise the driver with a warning light. It also provides coolant loss protection, which allows the V-6 VVT to operate safely at reduced power, even after there has been a total loss of engine coolant, so the driver can reach a secure location. Additionally, the ECM allows a number of other customer-friendly features, including GM's industry-leading Oil Life System
    The 2.8L V-6 Turbo also uses a torque-based control strategy, which improves upon previous throttle-based management systems that rely exclusively on the throttle position sensor to govern throttle operation for the ETC. The torque-based strategy calculates optimal throttle position, the position of the intake plenum plate, cam phasing positions and other operational parameters and translates that data into an ideal throttle position and engine output, based on the driver’s positioning of the gas pedal.
    The global V-6 exhaust manifolds are double-wall steel and the cam covers are aluminum.
    Low Maintenance
    The cam drive, variable valve timing and valvetrain components require no scheduled maintenance; the sophisticated cam-chain tensioner, high-quality cam phasing components and hydraulic lash adjusters are designed to ensure optimal valvetrain performance for the life of the engine with no adjustment. Advanced control electronics and a wide range of sensors allow failsafe systems, including ignition operation in the event of timing sensor failures. The control software protects the V-6 from permanent damage in the event of complete coolant loss, and allows the engine to operate at reduced power for a prescribed distance sufficient for the driver to find service.
    Even perishable components provide extended useful life. The spark plugs have dual-platinum electrodes and a service life of 100,000 miles without degradation in spark density. The spark plugs are easy to remove because they are located in the center of the cam cover. When the ignition-coil cassettes are removed, the plugs can be reached with a short ratchet extension. Extended life coolant retains its cooling and corrosion-inhibiting properties for 100,000 miles in normal use. The two accessory-drive belts were specified primarily for their lapless construction and low-noise operation, yet they are manufactured of EPDM rather than neoprene and should last the same 100,000 miles before replacement is recommended.
    A bottom-access, cartridge style oil filter requires only element replacement. The filter is easy to reach and designed to virtually eliminate spillage when the cartridge is removed. Moreover, with GM’s Oil Life System, those who own vehicles equipped with the V-6 VVT should never pay for an unnecessary oil change again, nor worry that the engine oil has degraded to the point where it has lost its lubricating properties. That, in turn, can significantly reduce the amount of motor oil used, and the amount of used motor oil that must be recycled. The six-quart sump capacity ensures maximum oil change intervals.
    The industry-leading Oil Life System calculates oil life based on a number of variables, including engine speed, operating temperature, load or rpm variance and period of operation at any given load and temperature, and then recommends a change when it’s actually needed, rather than by some pre-determined mileage interval. In extreme operating conditions, such as short periods of operation in very cold temperatures, the Oil Life System might recommend a change in as few as 3,000-to-3,500 miles. When the engine runs at moderate loads for extended periods with little variance, the system might not recommend an oil change for 15,000 miles. The owner’s manual in vehicles equipped with the 2.8L V-6 Turbo recommends an oil change at least once a year, regardless of mileage.
    Production for the 2.8L V-6 Turbo is located in Port Melbourne, Australia.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Gotta love how the 2.8 Turbo was made in australia but not made available in Australia.
    EDIT: I think it must use the same engine block as the newer generation Holden Commodores, Makes more sense.
    Sorry to be off topic, But does the 2003 Pre-face 3.2L GSi have VVT?
    I noticed at the dyno day that the engine hits a certain rev limit and changes engine tone quite dramatically. Just wondering if this is VVT kicking in.
    Bordon, Hampshire
    Thanks for posting the Engine information. Thats where I got my information from too lol..
    With regards to VVT. It shouldnt change the engine tone. Its there to make the engine run 'normal' when other things might prohibit it (change of fuel octane, air temperature differences...) If its the same as the MAN trucks we have in the army it should even make the engine run pretty normal with a knackered spark plug as it would rework the timing to compensate for the missing spark...
    However whether thats as easy to do on a petrol as opposed to a diesel (where its all based on the fuel vapour released into the cylinder and being compressed, not the spark to ignite it) i wouldn't know. I want a big geeky manual to tell me though
  1. what are the 1.8 and 2.2 engines like?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2010, 00:25
  2. Saab engines...
    By danBoy in forum Petrol Engine related
    Last Post: 14th April 2010, 10:40
  3. 2.0T engines
    By oz1988 in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2008, 19:15
  4. diesel engines
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2007, 08:30
  5. 3.2 Engines
    By Richard in forum Petrol Engine related
    Last Post: 13th February 2007, 08:32
vectra 2.8t oil change www.vectra-c.com
hfv6 2.8T
best spark plugs saab 93 aero v6 2.8t
best gap for spark plugs saab 93 aero v6 2.8t
vectra c 2.8t fuel pressure diagnosis
opel vectra c 2.8t engine heater
