Results 1 to 10 of 14
Thread: Weird indicator/light problem
    Sep 2010
    didcot
    confused Weird indicator/light problem
    please help my car has developed a weird problem when i turn ignition on the rear lights come on and stay on, then which ever way i indicate both rear indicators come on and flash faster than normal (as tho bulb has gone but checked all bulbs) but front ones are working as normal (appart from flashing fast) also electronic boot release stopped working. as far as im aware these all happened at the same time. have done a quick check of earth points and connections at rear of car all seem fine.
    does anyone has any idea's
    thanks
    mike
    milton keynes
    does sound very much CIM related or maybe BCM . if you over MK way time in the future I can have a quick look for you
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by kman247 View Post
    Could it not be the REC?
    Sep 2010
    didcot
    thanks for the reply, if it was either of these would it show as fault when i connect my laptop? cause it didn't show any faults, (but dont know how reliable the software is bought cheap on ebay) have done some checking found some bloke had similar prob with his saab and suspected REC, is there an easy way to test any of these?
    also just noticed when i turn ignition on should say insp on dash but doesn't now???
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    sounds like a REC problem to me
    Sep 2010
    didcot
    i had a mate do search for fault codes found quite a few so cleared them all that was left was: U2103 can bus circuit fault, U2141 Cannot connect to REC and P1565 Cruise control malfunction, and we were unable to connect to REC to check for faults. so not sure if fault lies with REC or can bus does anyone have any idea's
    thanks mike
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    In my limited understanding of these systems I thing the Can bus is what connects the REC to the other modules. Take the panel off the passenger side of the boot and check all the plugs are in secure.
    Sep 2010
    didcot
    thanks but already checked, does anyone know where the wiring for the can bus runs so i can check it
    Sep 2010
    didcot
    ok sorted problem turned out to be the rec, got one off ebay all working fine, thanks everyone for advice
    Regular Member kensri's Avatar
    Sep 2010
    Merseyside
    Im having a problem with just the N/S indicators flashing fast although all bulbs on that side are working. Could this be the same problem.
    Oh yeah also what is REC???
  1. very weird issue with indicator
    By gregj in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2013, 19:05
  2. Weird Problem with PC..
    By macdad in forum General Chat
    Last Post: 28th March 2012, 23:36
  3. Weird problem
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 19:12
  4. weird indicator problem
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2010, 10:45
  5. front indicator light problem
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2009, 10:58
