Thread: Still got EML on help please
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Still got EML on help please
    Hi,
    As above still got my EML on all the time with the following codes
    P0400-5A Low gas flow
    P0400-04 gas circuit open
    P0380-08 glow device genreal error
    Any help would be great checked all pipes no splits.
    Steve
    West
    EGR could be sticking - 0400
    preston
    blank your egr
    see what you get then.
    sounds like your glow plug(S) need changing too.
    that would be my first actions
    oh and check boost sensor / clean
    and vacuum hoses make sure not perished
    that covers most problems
    checked all pipes got new vacuum pipes on cleaned the boost sensor and egr. The only thing I can think of is when the egr vaule was off I should have taken the erg vaule apart to check if the egr valve was working.
    http://www.saabscene.com/forum/index...topic=31642220
    Looking at second photo should I be taking this apart IE the black bit from the silver bit?
    Is the valve located between the two?
    Steve
    Bump
    Steve
    preston
    the black bit contains the solenoid which operates the valve in the silver bit.....
    i take mine apart and clean the silver bit with carb cleaner
    the soleniod plunger should move freely. if it does then chances are its fine.
    if not then strip it down as per the how2 and relubricate.
    i did that and it works fine ever since
    cheers
    Quote Originally Posted by mparks8590 View Post
    cheers
    Thanks m8 will do
