Results 1 to 10 of 18
Thread: Smoke on hard acceleration
    Sodding Typical on Sea
    Default Smoke on hard acceleration
    The car is getting new strut top mounts on Friday under warranty, but I notice and have had a friend point out to me that under hard acceleration I have quite a bit of smoke this clears quick enough and lasts only 1 or 2 seconds at most.
    I plan to ask the garage but can anyone tell me roughly what is the source?
    EVERYWHERE
    Quote Originally Posted by Derek Mc View Post
    When was the last time the air filter was changed!
    I changed it myself at an indicated 19K now showing 23.5K
    I am glad you didn't mention the Turbo
    EVERYWHERE
    Check for usual stuff. Air leaks anywhere? Check tightness of clips on intercooler etc. Check for perished hoses. Clean boost sensor. Clean EGR valve. Check tur....no it should be fine.
    Cheer's DD,,,
    I have the Crankcase vent bypassed to atmos
    Cleaned out the throttle body (mechanism was bone dry)
    Cleaned flutes of the inlet mouth where the egr merges it was almost blocked by sludge and carbon so fully opened it all up.
    Cleaned boost sensor (it was dirty but not blocked)
    Removed egr cleaned passages and checked piston movement
    Oil changed 5K ago
    Airfilter 4K
    Running on Jet regular diseasel no additives currently
    No smoke at idle so believe Turbo fine
    preston
    are you running a remap or tuning box?
    No, just OEM mapping 150HP
    preston
    try cleaning maf sensor & then use a premium fuel for a couple of tanks eg shell v power or miller addititve
    then get your friend to follow
    I have the car going in to Vx Friday and if it had been something expensive I would mention it but as I have a modified Crancase vent, I don't want to cause myself problems I later regret,,,,
    It sounds as if it is more a symptom of gentle cruising followed by a hard blast while running on poor quality cough medicine derived fuel.
    Regular Member slinky270306's Avatar
    Aug 2010
    Devizes
    Could be burning oil if its like a few puffs?
    I got my other half to watch my exhaust when i rev'd up to about 4k RPM in 3rd and few little puffs came out apparently. According to VX, the VX mechanic said, apart from the fact my engine is thirsty, (2.2 Direct petrol) its acceptable for an engine to loose a litre of oil for every 1000miles travelled.
    Apart from laughing who was i to argue, i aint no mechanic but i always carry oil in the boot and check it regularly just to make sure.
    VX's are renound for burning oil, had it all through my 4 cavaliers, got it on my vec and bloke opposite has it on his omega.
    Check colour that might help narrow it down, White smoke, i would cry as that could mean head gasket but i wouldve thought this would be more of a constant, minor black/blue puffs i would say its just burning a little oil.
    Depending on how you check your oil as well to make sure to get definate true read of whats in your engine as i never check mine cold. Always get engine up to temp and leave for 5 mins after turning ignition off.
    Check dipstick and add oil accordingly if need be.
    Hope it helps =)
  1. Replies: 10
    Last Post: 6th February 2010, 15:00
  2. 3.0 cdti black smoke on acceleration
    By littlejohn in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 08:47
  3. Whistle during hard acceleration
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2009, 11:05
  4. 'Hard' Acceleration
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2008, 11:48
  5. Help 2.2 Direct Stuttering under hard acceleration
    By Geordie2.2 in forum Engine & Drivetrain
    Last Post: 22nd June 2008, 04:08
