Results 1 to 10 of 17
Thread: Fumes Entering Through Vents
    Regular Member s-owen4's Avatar
    Aug 2010
    Consett
    Default Fumes Entering Through Vents
    Hi Folks
    Fumes are entering the cabin of my 1.9cdti (150), through the air vents, this is only noticable when the car is stationary, I cant see any smoke in the engine bay or any exhaust leeks, any ideas????
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Just a guess but im sure there are vents in the lower rear quarter panels, behind the bumpers. Im sure they are there to help reduce pressure when your close a door. Maybe one has jammed open and is allowing fumes into the cabin, but only a guess.
    PRESTON
    Check egr gaskets are sealing correctly and also the egr cooler at the clamps. Ensure pollen filter seated correctly and the the under bonnet bulkhead seal is there and not damaged. Might also be worth checking the breather hoses for being loose.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Sounds like the inlet manifold for sure!, gasses will be escaping via the worn flaps and get sucked in to the vent at the bottom of the windscreen.
    Aug 2010
    Consett
    Thanks for the reply!!!
    The car only has 66,000 on the clock, it also has the new design inlet manifold, swirl flaps dont appear worn or loose??????
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    Did u have the air con on?my girlfriends corsa does it sometimes with te air con on! hth
    Aug 2010
    Consett
    Aircon on or off, makes no difference
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    sounds like a leak eleswhere then if you've had the manifold done!, look for sooty marks around the manifold/egr/throttle body area. also check the oil seperator and pipes s said b4.
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    Take the top cover of f the engine, run it and check around the base of the injectors for "chuffing" this was what it was on my 120 (only noticable when stationary)! If it is then a new seal is 50p from vaux and not a bad job to do either
    Justin.
    preston
    assume performance is ok.
    if not check whole exhaust system from egr through to manifolds.
    i assume you've ruled out other people's emissions??
  1. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  2. Diesel fumes entering cabin
    By matt_vec2007 in forum Engine & Drivetrain
    Last Post: 14th February 2009, 15:45
  3. Fumes Via Air Vents
    By leeds vectra in forum Bodywork & Interior
    Last Post: 4th February 2007, 15:46
